Yeah all your friends will think your awesome cruising down the street on your longboard and just don’t let anyone tell you that its not possible (that was a problem with me) Because it is.
Thanks gee!
Thank you for the support!
Which batteries do you think will work better on my board, https://meepoboard.com/collections/frontpage/products/battery-10s2p-36v-4-4ah-samsung-18650-5c https://www.ebay.com/itm/NEW-SAMSUNG-18650-36V-4-4AH-BATTERY-EBIKE-VAPE-POWERWALL-BATTERIES-20-CELLS-BMS/201895735309?epid=1621923126&hash=item2f01ec700d:g:Mh8AAOSwSypY9Y7d
there both 10s2p witch is pretty good. Im no lithium ion expert but i have to say the one from meepoboards is your better choices between the 2. It seems to have more range and you can get it with a case.
i personally use the 2nd option in my board and love it. my pack is three of those 10s2p packs connected in parallel so I can get a decent discharge rate. if your looking for light and plug and play-ish go with meepo board one. for the 2nd one to be viable you have to connect atleast three of them together for 10s6p
Do you think one of the meepo batteries will work fine?
I assume it will work well enough with just 1 seeing as it is the battery used in the meepo.
Ok thanks GrecoMan!
What do you think I could do to get my build price down?
to lazy to scroll up. what is your optimal budget? what are you at right now?
I’m at $475 right now, the spreadsheet I made is wrong
$475 is just about as low as you can go. i planned on spending about $400 on my build and am now over $2000 in
Ok, thanks, where can I find pic of your board
haha i’d rather not show a pick of my board, it’s a bit ugly . check back in a couple weeks and i’ll show you the updated and beautiful version
Ok, I will check back in soon
lol i’ve got a thread guys. lemme find it real quick
found it: http://www.electric-skateboard.builders/t/build-1-5-35-blank-deck-custom-10s6p-pack-paris-195mm-tb-vesc-97mm-clones-greco-v1-mount-sk3-192kv/37430/4 there’s a pic of my board right now in there
It’s not to bad.
for 2 grand I could’ve done better
