Hi all, thanks for all info on this forum…i’ve been reading this forum for the last 2 weeks!! It’s insanely good!
I am starting my first build single motor (TB 6374 190KV). I need help on how to take de best torque out of it (as i live in a hilly area - 15% - i have 75kg/165lbs), and still want a good range of around 32km/20 miles. I don’t really mind going much faster, as the asphalt in my neighboardhood is terrible (that’s why i am going with 90mm wheels but down the road will change to 97mm, i think).
My parts list (ordered so far):
Deck Bustin Boombox (stiff) - 38’’ - Battery + Eletronics space - 20’‘x6’’ (i could push a little).
I Just split the battery, and all solderspots seem fine. Used for one summer on rough pavement.
Getting a spotwelder early next week so building a new one with another structure. But battery held up nice.
Soldering was a hell of a job because you have to solder one parallell and let it rest and cool down before soldering it again. Took quite somw time just due to keeping heat distribution down
hi all, all my parts arrived. I decided to change couple of things.
Thanks to @NickTheDude , i have change the batteries to Samsung 30Q. Still 10S4P.
I also changed de Motor mount to reversed to use the little tail Bustin deck has. Will post more pics.
I have to say that my first battery pack was a challenging one. Thanks to @darkkevind i was able to spot weld my pack using his car battery+solenoid welder! Not perfect Welds, but good enough. Thanks there!
On the edges, to link the 5 packs of 2S4P i have soldered 10wg wire to a nickel support, and then welded on the pack. I did not weld directly to the pack as i was afraid to transfer too much heat to the cells, as i am not an experienced welder.
