Hey Guys! I’m currently working on my first DIY build and would love some help and suggestions on parts. Right now this is what I have picked out/already own.
Voltage Reader - $4
Not sure where to buy one, but I just want a basic one like the one on ownboards, maybe with a blue light instead of green so it matches the power switch.
Screws - $12
Remote - $50
Which remote should I get for the focbox unity? Dual V4 or V6?
Focbox Unity ESC - $250
Motor Mounts - Free
Custom Modified From Boosted V1
Buy your Sanyo battery off of meepo, it’s 50$ cheaper and it’s the same battery just sold by meepo, also that remote you choose hasn’t really been tested by any of us esk8ers but a @torqueboards nano remote or mini remote should get you going
They are both 10s2p and both use Sanyo 20070 batteries. I believe they both come out of the same factory. Same amount of cells, literally no difference.
Wowgo is def lying, there’s no way a 10a2p can get 28 miles on a single charge, in my own opinion buy a 10s3p to 10s5p off of @thisguyhere, or from @psychotiller. Way more reliable then the meepo and wowgo battery. The problem with these Chinese’s boards is there statistics are fabricated, they aren’t based on IRL
I got a broken V1 boosted board for free so I already have the deck and calibers free. The grip tape I wanted my own custom one, the enclosures I want to look professional. I will need to buy an anti-spark switch which costs $40 anyways so I figured I’d get the push to start since it’s the same price.
Go for a @psychotiller battery, can’t trust these Chinese sellers statistics, or a @thisguyhere battery, they won’t disappoint you. if you change the enclosure to a @bigben you’ll have a professional looking board, for near the same price you can buy a reliable battery that won’t have as much voltage sag and have a better range
I already have an ownboard battery and it gets about the same range they claim, plus it comes with a BMS and charger port already connected and uses the same charger I already own. They claim 12-14 miles I get 11-12 going full throttle the entire time.
Ahhh, I can’t afford $400 for the 10S4P pack. I will probably just use the battery I currently have until I have more money and then buy one of these if the battery isn’t doing it’s job anymore. Thanks for all the information man!
