Finally had the time to try this, the gap is still there. Any clue on how to fix this?
@torqueboards Hi ! I finally have my 4WD setup finished! it runs great! ,didnāt test it yet (rainy daysā¦) I only have a weird noise on the front/right motor, like vibes the other motors donāt makeā¦any idea about how to fix that? (motors 75 KV are brand new,so it should not be the bearings I guessā¦)
test ride today! itās like driving a tesla car! strong power, silence and comfort (thanx to the TB110 wheelsā¦) the board is quite heavy in 4WD : 15 KG without batteriesā¦) so you can feel the weight in curves, but heavy torque! it was worthy the delay it took to get my TB direct drives:1 year exactly!! (ordered in black friday 2018) and also the money,as my first direct drives had issues ,and all the costs I had to assumeā¦ (shipments and replacement)but now I ride a monster!!
what deck, battery, enclosure etc? any pics?
Beast mode
Also for anyone interested Iām selling my direct drive 75kv motors.
That is very cool. Do you need 4 VESCs for that?
the deck is a bustin nobach,batteries are 2X tattu 6S 16 Ah 15C(12S) , "enclosure " is a motorbike tank bag on the deck.ESCās deliver 4X60A to the motors
Can anyone help me with my 75kv DDās? I have had to crashes due to my brakes being weaker than I care for them to be. Both crashes have ended in minor injuries but could if been much much worse. Iām running a Unity, 75kv DDās with the 110 wheels, 20700B 12s4p battery. Here are my settings. Ignore the top speed on the Metr Pro app Iām not sure what thatās all about.
Increase battery current max regen to 25A, thatās the only way to avoid injuries
@ElectricCoast You can also use Current Smart Reverse and it works pretty well. Iāll have to make a tutorial on it though.
@Eboosted osted 've increased my battery current max regen to -30 and itās still the same. Iām completely befuddled. My Kaly with gear drives are set to -11 and they work amazingly.
Yeah a tutorial video may be helpful @torqueboards
Thatās impossible, there must be a noticeable braking force going from -15A to -30A.
You will have a stronger braking force but only at high speeds over 25km/hr, at lower speeds there will no much change, so the next question would be, are you braking in low speeds or high speeds?
Lower speeds under 10mph maybe. I donāt get it though my brakes on my other board are amazing set at -11. I canāt even sit on a 5% incline with the brake applied without the board rolling backwards.
This is completely normal. I think you are not testing it corectly or you are comparing coimpletely different ESCs or ESC firmware versions
Same exact escs. Theyāre both FOCbox Unitys with the same firmware.
There must be something weird here, maybe the KV of the motors?
@Eboosted Torqueboard dd 75kv motors on board with braking issue. The other board had Torqueboard 6380 170KV motors on the board with awesome braking.
