Of course, just make sure you open it up and hot glue the coil to the board. I broke the first one quickly with the vibrations. I opened it before I sent it back and the coil had broken off inside it. The coil has no support and will break due to heavy vibrations from the board. The second one I got in exchange I opened up and hot glued the coil in place. Problem solved as of now.
Awesome mount. Look forward to seeing it on thingiverse.
Thanks @mcfly777
The wall mount is up on thingiverse now. I am wondering who is going to really print one after they see how long it takes.
Sweet, thanks!. If it fits my printer might as well print it
ok you demand proof I checked and it’s a 12h+ print so I’ll try later today
Ok here’s the first attempt. Failed in the middle of the night. I think I’ll use this as the right and cut off the part that failed as it still can hold the board. I’ll print another one tonight, hopefully it sticks.
Leo
The drop through covers are up.
Loop Key Mount: http://www.thingiverse.com/thing:1558717
Digital Voltmeter: http://www.thingiverse.com/thing:1558740
What printer are you using? Looks like its missing some and finished the top lower…
Could it be that it was printed without supports?
Hi I had removed the supports already. But the problem was that at some point the object came loose, and the top continue but offset…so I took it off
It’s a Qidi printer FWIW.
Leo
this is a seriously sick build. The custom printed parts look great!
Has anyone printed any parts for their boards? I would like to know what ya’ll think of them and see some pics.
@mcfly777 and @Blasto were making some wall mounts. Any pics of those done and on the wall?
Haven’t tried a second attempt yet. I’m actually waiting for the release of your controller
I printed 2 wall mounts, one printed perfectly, the other didn’t complete and I printed just the top part that was missing but it’s not perfect. Anyway, I have not hung the parts on the wall yet.
As for other parts, I printed one wheel pulley from thingiverse and it printed really well and strong. I’d totally use it. I wont use it since I ordered parts from @torqueboards and I’m waiting for them to arrive.
Other things that I see as easy to print: enclosure (I have a thread here), truck hole covers, bumpers, LED holders, etc.
Leo
How did you wire the batteries do u have a diagram? Thanks.
I don’t have a diagram, they are just 4 batteries in series.
Where you get the lcd for a 12s? Thanks
Where did you get the 280mm belt, I’ve been looking all over and need a longer one for reverse mount
