After finishing my electronics upgrade of my Evolve GT, I powered on the VESC and connected it to the VESC tool to set up the motors. Unfortunately, the left side of the VESC soon started flashing a red light and now won’t turn on at all. The left green led does flash when powering up but stays off afterward. The VESC-tool also cant connect when I attach the USB-cable to this side of the VESC.
When it was still flashing red, I tried to diagnose the problem in the VESC tool, but I didn’t see any faults show up. Maybe I checked the wrong place?
I can’t see any burn marks on the pcb or mosfets nor did I smell anything burn.
Any help is much appreciated, I was sooo close!
Board Specs
10s4p Samsung 30q
Besttech HCX-223v1
Flipsky Dual 6.6
Metr pro module
Nano remote
Yep, I have had the same issue with all 3 of my 6.6’s. I would recommend staying away from them. You likely did nothing wrong. Unfortunately, only vesc 6 I trust is the official one, which frank charges an arm and a leg for. I burnt out 3, which is the cost of a vesc 6. So I really just lost in the end. Not worth it, just buy the real deal.
It fails to load the bootloader it seems… You can’t connect, you just get a blue light, no red or green. It’s either failing to load the bootloader it getting stuck.
Dont think so, at least I cant see anything that’s shorted on the board. When you say heatshrink do you mean the plastic cover of the vesc or the battery heatshrink?
I’m not quite sure what the problem is. I just know there is a design flaw. I can’t tell you how I know, but it’s true. Don’t waste your money on it. Return it if you can and buy a better one.
I contacted them and they responded already so at least that’s positive. It seems like I might have to reflash the firmware. Will keep this topic updated, might help others if it works.
flipsky is already in contact with BV, and donated a few hundred euros to him so far.
BV gave them some design input, not sure what happened after that. Been pretty radiosilent.
