Ok I have done my fair share of reading. I just blew out my first vesc by burning the DRV.
My setup - All TB products VESC’s, dual 6374 190kv motor, 12s4p battery, 100mbs wheels, 16/36 gearing but soon to be 16/40 with either 97 or 107abecs.
I was being dumb trying to shave down my MBS wheels like kaly and one vesc blew out. I was in FOC mode.
My question is. To avoid burning another VESC, is FOC to strenuous for my setup because I’m already pushing the erpm limit? Should I just stay in bldc mode? I want my board to go consistent 30-35mph without blowing out anything
First foc to from what I have read only supports 10s or is very not stable at 12s , second you can’t just throw any vesc into foc most vesc on the market will get the DRV blown because the components quality is not good enough, if you want to run foc the only good vesc to do that are , Ollin vesc , Enertion and vesc 6.0 someone correct me if am wrong here
I’ve don’t know , I assume there is a sensored bldc , I’ve never done it , but yes sensored has a gradual acceleration on start up smooth , I’ve seen a sensored board before
Focbox! Obviously there have been cases of DRV’s blown on FOCBOXes but very rear. I’m not aware of any totally bullet proof vesc but focbox seems to be a winner lately. vesc 6 could be game changer as well
Not true. I run 12s FOC (or should I say, ran ) with hummies v4 motors, never had an issue with 12s and FOC.
But again, this is with hub motors. The reason your hearing this is likely the erpm limit. Because belt drive motors spin at higher erpm’s, they can get closer to the limit and in a lot of case, go above the limit and thus blow their DRV chip. If running hub motors, since its a 1:1 gear ratio, you can’t get close to the erpm limit unless your going like, 60 mph, maybe then. So 12s FOC with hubs is safe.
You are right though that not every vesc is equal. I use chaka vescs and now, I’m messing with FOCBOX’s. They seem to support FOC fine. Again, don’t go over the erpm limit though. That is why the DRV blows more often than not on the FOCBOX or a chaka vesc.
The only one I can say is Ollin Vesc. I’m sure FOCboxes are great and have 2 of them myself, but I haven’t used them yet. Those and the VESC6 for obvious reasons.
I run BLDC sensored and I think it is way better than just the standard VESC sensorless. To be more specific I run it in hybrid mode so that at higher speeds it switches to sensorless. Perfect smooth startup every time.
190kv is too high for 12s on v4 VESC hardware, FOCbox included. Did you have a 60k ERPM limit programmed? You probably wouldn’t reach this limit while actually riding it, but were trying to shave down the wheels with the board unweighted. Sounds like the source of your DRV failure…
Yep just click hybrid, and do motor detection with the hall sensors and fill it into the table. Obviously you have to have your motor sensors connected to the VESC
