Hello everyone!
I have a problem with my FocBox Unity. I’m trying to detect hall sensors in my motor but without any good results. I’ve checked the phase wires, checked hall wires, everything is okay. When I connect motors to normal FocBox, not to Unity, everything is fine. But when I connect motors to Unity it can’t properly detect hall sensors. I’m using RacerStar 5065 motors. I have few of them and always is the same problem - it cannot properly detect hall sensors. I’m attaching screen to this topic.
Waiting for your reply and maybe for problem solution.
I’ve chcecked soldering on phase wires and on hall wires. As I said - everyting on motor side is okay. So what should I do? Check soldering on Unity’s phase wires?
Try swapping your phase wires. I had this same issue, for some reason hall sensors were not detected in one configuration but when I swapped two all was well
