So im almost done completing my first board and i cant make up my mind on this last part, should i spend the money and go dual 6374’s or buy a TSG Pass and go single 6374? if i go dual i have a motorcycle helmet i can wear but i hear that might not be a good idea considering weight and field of view… so what should i do?
(i cant afford both right now, so what i end up going with is what i’ll have to live with for 3-4 months)
and for reference (or whatever else) this is my motorcycle helmet that i’d be using for the for seeable future if i dont get a tsg:
depending on your skills and if you have ever skated you can get a brain bucket type helmet that will be better then nothing. how fast do you plan on going on the board?
ive never touched a board before… but i have had my board for about a month now and ive been getting used to it as much as i can. and i plan on cruising at like 15-20mph probably.
also isn’t it hot as a mofo out there? the tsg doesn’t have great ventilation with the visor down maybe look at a full face mountain bike helmet it’ll have a lot of breathing vents
totally agree , I had a full face BEFORE my first eboard even arrived (and I’ve skated ~34 years!) I saw what happened to Kevin Pearce (snowboarder) - Wikipedia don’t risk your ability to skate just to go faster!
I find the “tsg pass syndrome” the most intriguing.
Any good helmet is up for the job.
If you own a motorcycle helmet use it. Unless It is a very low quality one It will be better than the tsg.
I use the same helmet i had for my electric bikes.
Its actually been really nice the past few month surprisingly. and i already have a 6374 motor so its too late to go 6355’s… the full face mountain bike helmet is something i may consider but i really like the small size of the TSG, always found dirt style helmets a bit big.
i’m really leaning towards just using my motorcycle helmet tbh… i did some research about why its a bad idea to use a MC on a board but i mean, if my MC helmet can save me flying off my bike at 80mph+ i should be find taking a tumble off a board going 20-30 right?..
Haha i know your setup actually helped me out quite a bit when i was trying to figure out how it’ll all look/work out when its done you’re the only other person i’ve found thats using this board
Going dual is also a safety improvement, as braking is so much better with two motors. That’s the most important gain with 2 imo. Insufficient braking power could also kill you. A good helmet is a must though
