Your CAN transceiver blew, remove U401 and-or replace it
@scepterr has the focbox now, seems like the pcb died. Im waiting for enertion to ship out some new ones
Lol yeah that one was a doozy, blown up fets, shunt, burned traces
did it come like that?
Naw it came working perfectly, put many miles on it and then boom! Bad soldering skills
Actually The one vesc that iāve had fail was from tb. and it was not user error. it was cold solderā¦ still gotta fix that paper weightā¦
iāve done this for a bit, but 200kv is nicer on 10s.
Did it work?
yes ti works, but i never went full speed with that setup. the top end is where the problems would happenā¦ either way its not needed. the speed can be had with other more reliable setups.
Lolā¦ Hmm Iāve heard this story beforeā¦
Iāve had multiple foc boxes and Olin vesc on 10s and 12s for 245, 110, 149, 190, and 170kv no problems
I completely disagree. The Vesc work perfect and the price is right if you are on a budget. Iāve bought 5 vesc all from @torqueboards and the only issue Iāve run into was because I didnāt set up FOC properly
for 245kv did you limit the erpm or the top speed some how?
I actually never limited the Erpm Iām just super light and never went fast
Ok, but do you think that If I use an Ollin Vesc, and limit the erpm to 55k, I should be safe? I doubt that I will be going over the erpm anyway because that is over 30mph for me. Are there other ways to limit top speed?
I think that will be fine just donāt try racing the board, I would say if you want to never have to worry get a 190kv motor
Ok, because I am on a limited budget, what inexpensive 190kv motor would you recommend. what could I do with my old SK3? Its in very good condition with limited riding on it. What about this one that I found https://hobbyking.com/en_us/kd-53-30-high-voltage-brushless-outrunner-190kv.html?wrh_pdp=3&___store=en_us
That one works
Is there a reason the I should beware of because of the lower price than the SK3?
Nah just look up the motor in the search function u arenāt the first to use it
