Hellboy | Eboosted Enclosure | Sector 9 Meridian Board | FOCBOX Unity | Evolve Supercarve Trucks | Psychotiller 6369 Motors | Unikboard Motor Mounts | Pelican Bay 12S4P Battery | ABEC 107mm Wheels | Hoyt Puck Remote
This project started innocently enough with a simple attempt to upgrade the battery on my Evolve GTX. But after lots of feedback from the forum, I ended up replacing almost everything except the Supercarve trucks and ABEC 11 wheels. I didn’t want to take a lot of risks with the design, because my main interest is in actually riding the board. So I looked at similar solutions here on the forum and reached out to various people for proven components.
main_board
This Halloween I dressed up as Hellboy, and since I was designing this board around the same time, that name seemed to stick. My goal for the board was to capture sleek California style with stripped down simplicity. This board is designed for power carving residential streets with plenty of torque for climbing hills and quick acceleration. The color scheme is banner red and flat black with yellow accents.
hellboy
The enclosure from Eboosted was wonderful to work with. Super tough but easy to drill and sand when needed. The enclosure was designed to fit the Sector 9 BinTang, but I liked it even better on BinTang’s big brother, the Sector 9 Meridian. The generous 40-inch deck size makes sense for an electric board. I am about 6’ 2” tall, so the larger deck feels right.
Handy Tip: If you rub any of the Sector 9 boards with Acetone everything comes right off, including the decals on the bottom, and the grip tape as well. After some Acetone applied with paper towels the board looked like it was fresh from the mill. I didn’t sand a bit! I suspect this trick will work with many other brands as well.
IMG_8219
IMG_8228
I installed the enclosure with stainless steel rivet nuts. They mount on the deck and extend through to meet the bolts below. This method provides lots of strength for mounting the enclosure vs. inserts. I was careful to drill straight down into the deck, but since the deck has some camber, the rivet nuts made the top uneven. I countersunk the holes, used a Dremel to grind off one side, and Bondo to fill the other side before applying grip tape.
deck_camber
grip_tape
As you can see, I am charging the 12S4P battery with an external charger. I don’t like all the wires and complication of an on-board BMS. This way, I can manage the battery and see all 12 cell voltages while charging. I plan to build a mountain board someday with a similar setup, so the Chargery C4012B seemed like a good investment. This charger has worked very nicely for the intended purpose. I like the simplicity of the built-in 1500-watt power supply.
battery_connection
The flexible 12S4P battery was built by Roby over at Pelican Bay Innovations. He showed me how to connect the 12S external charger and also helped with many other aspects of the project. There are 48 Samsung 30Q 18650 cells on board, so we have maybe 50 volts and a capacity of 12 Ah. This battery definitely addresses the limitations of my original Evolve GTX.
12s_charger
Handy Tip: The Chargery C4012B supports many different battery types. The first type listed is LiPoAHv. Select this type if you are charging Li-Ion as well. Also, you will need to enter the total capacity of your battery pack into the settings menu. For example, in my case that was 12 Ah. Otherwise you may get an “over capacity” alert while charging.
IMG_8485
IMG_8447
I 3D printed a magnetic snap-on cover for the external charging cables. This protects them from dust and debris to some extent. There is also a foam rubber baffle glued into the enclosure. The foam presses the cables against the bottom of the deck and provides some water ingress protection. I might do more waterproofing later, but hey, it’s California.
IMG_8482
I love the Evolve Trucks, they provide a fluid carve line plus reasonable stability at speed. Mr. Tiller was kind enough to supply the dual 6369 motors, they definitely fit the style of the board. The Unikboard Motor Mounts are just perfect and complete the drive train. The wide 15mm belts look cool and fit the ABEC 107mm and AT wheels from Evolve. I 3D printed the belt covers to protect the pulleys. Let me know if anyone wants that 3D model.
Handy Tip: Upgrading your Supercarve trucks to 63mm motors will require new mounts. Unikboards makes a great one that supports Evolve street and AT wheels. Here are the right 15mm belt sizes for this setup: 15/32T = 280 mm belt, 15/38T = 300 mm belt, and 15/65T = 380 mm belt.
https://www.unikboards.com/en/boutique/core-serie-support-moteur-pour-truck-evolve-supercarve-street-et-at/
IMG_8473
I am starting out with the FOCBOX Unity set up for roll to start and automatic shutoff. This fits the stripped-down style that I am going for, but I might add a power switch and battery meter later on if desired. The Hoyt Puck remote works great with the Unity. The power train and acceleration provide a huge rush of excitement when this board takes off.
cables
Handy Tip: There is an easy way to convert the FOCBOX Unity 3.5mm bullets to the 5.5mm bullets found on many 63mm motors. If you get a 5.5mm and 3.5mm set of bullets, you will find that the wire side of the male 3.5mm bullet can be forced into the wire side of the 5.5mm female bullet. Then just hit them with some solder and you have a converter. Be sure to cover them with heat shrink wrap and electrically isolate them!
For me, the most interesting thing about this project was the people I interacted with here on the forum. I purchased my enclosure from Peru, the motor mounts from France, the motor controller from Australia, the battery from Denver, and the board right next door in Santa Cruz. The ability of individual forum members to build things with 3D printers, CNC machines, and homemade circuit boards has been a real eye opener. We are definitely entering the golden age of electronic skateboards!
beautiful :heart_eyes:
Edit: does the rubber padding on the enclosure help.woth vibrations?
That was my intention, to reduce vibrations and add some water protection. Not sure how it is going to work.
Can you link where you got it? I’m trying to do something similar
How do you like the Hoyt puck? I have two evolves that I am either going to sell or gut (mainly due to battery and electronics).
The Hoyt Puck is really nice. You forget you have it in your hand very quickly. It hooks right up to the Unity. I am running my Puck on Mode One (slowest) due to the ferocious response of the 200kv motors + Unity and the 124P battery.
I liked the Evolve remote however. The problem I had with Evolve is that very little of their parts are standard and interoperable. So I really couldn’t use many pieces. In my case, I sold my GTX, it was in good shape, and just bought new Supercarves.
Very nice and clean. Looks like you were very meticulous with your build.
But the unity has a power switch? Are you just going to rely on push to start and auto shut off for now?
You could just use a Bluetooth app to monitor your battery level and not worry about an external battery meter. :+1::+1:
Enjoy those 200KV power-plants. They are beasts!
Very sleek. Props for the attention to detail and final finish
Good looking build, your attention to detail was evident.
Yea. I like the evolve remote but the electronics is too questionable. I haven’t had problems but might be a case of when not if something were to go awry.
Don’t know how to got your hands in a unity so quick! I’m in line for Jan or March, so I might just use two focboxes I have here
Anyone got a nose guard 3D file for this deck? Or anything similar? Thanks in advance.
So tidy, awesome to see it all come together.
Awesome build - looks like you’ve gone with what you consider to be the very best option for each component. No short cuts, no skimping. I bet you’ll be very happy with it as a result. As a GTX owner, I can say no doubt the GTX is fun to cruise on, but the Hellboy is what an evolve could be.
I started down the path of no compromises, but nearing the end now and have skimped on motors and bms due to budget constraints… hopefully I don’t regret it!
outstanding build, 10/10
Wow thanks all, this was super fun!
Thanks for your comments, dead on. Can’t wait to see your build!
I can’t wait for my build thread either - like you I want to wait until it’s finished!
Hey Bill, I’m wondering about whether to add a loop key to my build or just rely on the unity’s switch.
Personally I don’t like the look of the loop key, don’t really have space, and would rather not hack up my enclosure.
It looks like you are relying on the e-switch. What’s your thoughts on that? Did you consider a loop key?
The FOCBOX Unity switch works great. I don’t much like the loop keys either… Roll to Start works great too! Shuts off after a few minutes of inactivity.
The Hoyt Puck works well with roll to start. When you turn on the Puck, it beeps because it is not connected. Then you push off the board, and the beeping stops when the connection is made. Very slick.
The Puck is very friendly and can be tucked in a pocket. This is different than (say) my Evolve remote which had a carrying case. Some other remotes are not strong enough that I would pocket them. A future feature I would like for the Puck would be showing the battery level on the LED circle.
The biggest problem I had was that the throttle was too low in the first half of the wheel and too high after that. This was corrected with the Power Curve editor on the FOCBOX Unity. That is a great feature I did not see in the interface until I asked support. Still, it was a little confusing until they told me that the remote % was on the X axis and the power output was on the Y axis. Anyway, this made a big difference in the feel of the board.
curvy
