I bought motors to big for my trucks…I have 15mm for a motor mount and sprocket set…should I use a 0.25in steel plate with countersink screws and #25 chain or a motor clamp and a 12mm belt?
I didn’t get around to adding them but it is a dual drive, although its geared for torque, do you think they will hold up to really aggressive acceleration?
Using a 1/4 in plate for the motor mount I only have 8.5mm from plate to wheel so I need a c-clamp mount to get even a 9mm belt, have you seen that type of mount before?
An option I considered at one point was to stagger the motors - Have one in front of the truck, and one hanging out the back.
It’s like a dual diagonal, but on one truck.
The maytech motors make it a tighter than other 6355s, because they’ve got that nub sticking out the back.
Ah ok you already have 6355 motors.
Thought it’s 6374 size.
Just if you calculate your battery max output it’s like
12s x 4.2v x 80a = 4032 Watt
So with two motors rated to 2200watt you would have the same power than with two motors rated for 3400watt
Unfortunately I think you’ve kind of backed yourself into a corner. If you can’t go staggered or diagonal, you either need wider trucks or shorter motors. There’s just not room for mounts and pulleys in there.
