Its been a while since ive done a diy board and i ve forgotten a lot of the lingo and math behind it…
am i correct in saying that if it get a certain strength of esc and battery… and all that i want is 15mph… i can trade off some speed for torque and get a lower kv…
im pretty sure i want 10s… and not sure if theres any reason why NOT to do that since its apparently most common…
the maytech style motors on ali express are 36v…
i know absolutely nothing about what esc to get… (or even what a vesc even is)…
i have no idea conceptually what amount of amps to chose… given that im pretty much going with 36v…
am i correct in saying that like most electronics… if a battery is 36v… then the motor must also be 36 volts no less… but the amps are basically the fuel tank… are motors rated for amps??? or watts or something like that?
i havent really been able to find a beginners guide to spec-ing out hub motors… only random old school articles from 3 years ago with pictures of enertion belt drives…
the reason i am going with single hub is
A: im only needing 15mph so if i get a typical 20mph system and then just trade off speed for torque in a lower kv motor (probably made no sense there)
B: its already widely done such as on the acton boards… not saying these are amazing boards but they certainly work for my needs… and just sayin… dont act like its not “a thing” to use one hub motor… its rather robust for what its intended for…
C: i am using a pair of extremely rare custom trucks that are smaller and narrower than usual trucks and dont stick out from underneath the board… they only fit one hub motor… with the square insert thingy on the hanger
the deck i am using is smaller than a penny board (extremely mini) i have already been able to fit other electronics setups on it and if i run into problems can always just sacrifice kicktail space and move the trucks farther apart…
I have a pair of super rare trucks that are extremely narrow and fit completely under the deck… unlike ANY other hub motor trucks i have seen that jut out very wide and completely defeat the purpose of a small portable deck… (also i have no problems going high speed with my feet basically scrunched onto a tiny board and hanging off the sides etc… im used to it… even without griptape i have done many times… slightly drunk… etc… its all about portability for me… and maybe even the ability to slide into a backpack but i plan on figuring out some kind of hook system to just have it attatched to the side… i know for damn sure with those giant hub motor trucks commonly available it wont fit inside anything much less a backpack… so i am using these very rare mini hub motor trucks… they only fit the maytech style mount not the ewheelin…)
im prepared to drop a couple hundred bucks on a motor, batteries, esc, remote… etc… i dont really have time to fuck around and have a lot of responsibilities going on right with work… and just want to buy parts that are compatible and match and wont explode on me… and will meet my STATED needs… much appreciated…
