The master/slave scenario is so 80’s haha
Well it’s good for traction control and advanced cruise control or to update multiple vescs with a now drive mode via smartphone app.
I’m upgrading to dual motors and I plan on going the splitter route. Do you have to use any reduced vesc setting values or do I just copy the values I have on my original vesc?
Simplest thing to do is half your battery max and min
Thanks for the advice. Will this reduce my performance?
No. You’ll have dual motors. Use the search function for a better explanation
The guys are right! Not sure what you have your motor amps at, but most likely you can up those values too.
Motor max 90 Motor min 50 Batt max 35(was 70 with single motor) Batt min -12
63/74 12s lipo
What was your battery min before? Motor min is -50 right?
Yeah -50 motor min batt min was -14 with single motor
