After the Hobbyking Vesc got taken offline a while ago, it seems to be back but rebranded as an ESC (apart from the url lol).
Has anyone had a chance to try one of these yet, would be good to see a review. They claim - Bootloader and Firmware Loaded. With Motor Detection & FOC Tested.
nah with no direct fet, think itās ganna be a good cooker. why do they hook it up with 125kv motor otherwise. obviously it lacks motor amp in foc.
probably better than Maycrappy vesc tho
Hope itās possible. Definitely bringing down the cost of one of the most valuable components. On one hand thatās great, on the other, what corners did they cut?
Compared to the average 100a RC car ESC going for $40. The extra $30 for regen brakes, custom throttle curves, higher than 4s batteries. If it works, it should be a very popular product for DIY builders. Iād order one now if I wasnāt broke from my other hobbies.
As for the suggested combined motor, I doubt much thought was put into that, hope no one accidentally buys one.
focbox 4 ex factory price is around $50 plus from china. obviously they need make margin so thatās probably 100 percent margin when everything considered. (Austin dollar is cheeper) given that this would factory cost about under 30. Just speculation but shouldnāt expect too much from
They have also uploaded a āmanualā. Does this give anyone any insight on the quality of them? I there any way of telling if these are missing or have low quality components?
Also does anyone have any expirence with Hobbykings return policy, they state they run FOC so if and when they blow could we just return them under there 1 year warranty?
Received one yesterday, here are 6 images in case they are any good to anyone. I expect it to fail like so many do due to the VESCs poor design. When it does ill try the warranty, then just use a regular ESC.
Will be a week or two unfortunately, the parts are nearly hear, but ive a broken foot lol.
Ill be running 12s2p 5000mah 30c, 6374 192KV, 6:1, 200mm wheels, im 65KG.
Ill limit to 60,000 erpm
Wont use foc mode
Upgrade filter caps to 100v low esr
Small wire as possible from battery to ESC ( 3 inch)
Cable tie the leads together
Active cooling with a fan, maybe heatsinks, however i dont think its very effective on the wrong sides of the mosfets.
If it still fails, there is no hope for thr turnigy vesc lol. Ill update the post asap.
Just from research. Ive read so many post of the drv8302 burning up when users tested foc mode, apparently if you upgrade the c26(I think) capacitor it lessens the probability of damaging the drv8302 in foc mode. Im just staying away from it to be safe. Im too poor to keep replacing Vescs lol
between motors and speed controllers Iām sure there will be plenty of people interested in what you have to say
wonāt be long before people will be dropping your name in postsā¦
shame you donāt do batteries as well
I inherited this project but I can build anything you like. Iām here to learn a bit more about what the community is after and how we can facilitate. Have you got a link to the project you referenced?
