Hi, I have a [6355 190KV Motor] (diy-electric-skateboard-kits-parts/electric-skateboard-motor-6355-190kv/), two 5000 mah 3s1p 20c Lipo Batteries and a Vesc 4.12. I found that my motor has been going slower than usual.
190kv is a bit low for 6s. I’d upgrade to 10-12s or throw another 3s lipo in there for 9s. You can change gearing for more speed, but right now your setup isn’t the most efficient.
Also, run and apply motor detection, it’s at default right now.
Thanks for the quick response! So what batteries should I get… Including mah, cellls and c. Also, should I change anything in my settings besides motor detection? Thanks again!
I know someone with a new 6355 260kV motor that is looking for a 190kV that you have. If you are interested in a swap, let me know. That will fix your problem instantly
You say you want to go faster. How fast are you going on your current setup? I am running 2x3s 5000mAh 30s batteries on a 6355 190kv motor. 16Tx36T on Orangatang Kegel wheels. Yesterday I went 9 miles on a charge, averaged 13.7 mph and maxed at 18.5 mph. Elevation gain was 111 ft.
I’m no electrical D.C. Motor expert, but I’d caution you about the lower kv / higher torque assumption. There are extensive threads about it already. I have a 260kv and more torque than I need. Adding the extra 3s to go to 9s is a solid suggestion. Get creative and make the room if you can.
More importantly, if your board used to run at twice the speed, and you haven’t changed anything in your setup, then you have problem to investigate. Just adding more power is akin to turning up the radio when your car starts to make a knocking sound.
I’d take a good look at your batteries. You say that you had performance and are now losing it. Perhaps your cells might be getting a little tired, and sag their voltage under current now. Are you experiencing a drop in range?
I used some cheap lipos for my first build from hobbyking. I was also using a vesc, a 4.12 from Enertion. The batteries were great when I first bought them, the board had a lot of punch. After a good amount of cycles, the performance dropped significantly, both acceleration and range. Built a new pack and had my performance back.
