I’m having trouble figuring out the wiring setup for the battery? can anyone help me, i don’t understand why you have to desolder the mini usb and how to wire it for the charging?
All i know is you plug the RBW wire on the PCB and the other side goes to the battery.
You remove/desolder the USB charging port. You connect wire from that USB plug from the red/black to +/- on it - down a few inches on the PCB (the brains of the GT2b) - to the bottom right connections. In my pic you can see them just above and to the right edge of the blue radio module - i have them sunk into hot glue to insulate.
When you remove the module - all you are doing is reconnecting the contacts w/ wire in-between to move the USB up to the top location. So if you mark the USB plug and the PCB as you remove it - they should be easy to identify what to reconnect.
here you can see the bottom of the board - as you remove the USB plug you can mark what wires to connect A->B:
Thank you for your help. I understand now, I have the mod made by @MasterCho and he’s just let me know I don’t have do anything with the USB port as the mod is perfect size for it
