Thanks, I had a plan to place lights on the cutout for the drop through, I can fit 4 high power leds on the front and 6 WS2812 on the back. With them off it would be almost invisible
Let’s see when everything arrives, I will try booth before putting the motors and electronics
My motors may have to be too low using the drop since my motor mount is only 65mm center to center
They already shipped to @bigben in UK and are shipping to USA Monday. Hope the Chinese tarrifs don’t come up. They should be here before end of next week
There’s a bunch of two hole ones that @hummie has to be used with His planned compression packs. You could wait abit until he’s able to put that together as well
So we can expect to have the same issue with the newer decks?
Doesn’t worry me too much as I was planning to top mount it first before I even try drop through but what kind of modification are we talking about here?
Is it because of the deck thickness that there’s not enough clearance from the baseplate to kingpin?
As far as I can tell, no changes has been done to the design except the double cutout hummie wanted on a few.
It’s not the thickness of the deck, it’s the hole that needs to be a bit wider/longer so you can fit the hanger there. Tb plates are a bit longer than calibers.
I’m hangover as fuck so that’s the best explanation my brain could think off
Guess I’m sticking to top mount for now then I’m already asking @psychotiller to increase the hole dimensions so I don’t know if widening the hole would be a bad idea so I’ll leave it be for now
