Question: Why not get 2 or perhaps 3 (depending on how wide they are) 80-100mm (depending on your preference) inline skate wheels and bond them together to make one longboard wheel? It would be much cheaper than buying ABEC11’s and there’s more choice. Perfect alignment can be achieved through placing them on an axle while bonding…
@darkkevind it’s a good idea, and clearly possible. The challenge I foresee is (if you don’t wan to develop your own hub-motor system) you’d need to mount pulleys onto the wheels, and there are no mounting systems that I’m aware of for this purpose; you’d have to figure that out.
Also, There might be some contact patch issues with the three-wheel grouping.
It’s ok, I’ve already fabricated my own sprocket & mount for my board so I’ve no problem with coming up with something for the inline wheels… but good to know that it wasn’t just a stupid idea that someone had already tried before and failed.
I have just mounted 4 wheels to my board 100mm to try, only done 500 m or so (because of bad weather) but so far it works ok. Think the speed will be faster as i had 78mm before. But I will feel more safe to have some Flywheel clones or something on. We will se how it goes =)
