Do you have CAD of the deck?
Oh forgot to mention, im 165cm, 5ft 5 i guess
According to their site the orbiter wheelbase is 15ā. I emailed them and they said the center of the bottom of the deck where itās shorter is 6.75ā wide. The outer dimensions of the coupe are 12.5ā by 6ā.
You would know more than me if this wonāt fit though. Iām just going by the numbers.
I had a coupe enclosure last time. From the looks of it, it MIGHT just fit, but you will need really short motor mounts or even a gear drive.
Yeah looks like 3dservices only sells the gear drives as a pair. If I go through them Iāll have to sell one. Is that a double layer of cells in the second pic of the coupe?
Yep itās a double stack, but it needs to be staggered than have the cells directly above each other
Before you order anything, ill check with @nuttyjeff because he has a friendās board with the coupe enclosure and hopefully one orbiter deck lying around.
Great thanks a lot
Nice build!!! Looks really cool.
What is the final weight of your board?
When i weighed it last time, it was without the enclosure, at 5kg. With the enclosure i think its an additional 100g maybe? Ill weigh it again tonight
Nice! Thats a good weight for a commuter! I tried the same. but i have now 8.7kg totalā¦ but with 10S4P and dual Hub motorsā¦
7s2p gives me 22km with a bit left on a single 6355. So for a commuter iād say a single drive is good enough.
trueā¦
7s is a bit less for me. 10S is the minimum for me. Maybe its worth a try with 12S2Pā¦
Just do 7s w/30Tās. Will probably have to slightly modify depth of enclosure
