Lifepo4 is 3.6v full, 3.3v nominal. A123 is a premium lifepo4 that can do unusually high rates of charge and discharge, and can take a lot of different types of abuse. Lowest I’ve seen is about $6.5/cell.
Oh and if you look at cycle life, it’s cheaper or even with li!ion. 3x rated number of charge cycles, But you get less “C” capacity per dollar.
I’ve been waiting on Black Friday focboxes and remotes to get this built.
I do have it set up as a push deck and I like it so far.
Nice to have a little tail on it.
I had a Truncated Tesseract previously and I found that a bit small. (I’m 6,6 though)
I have 2 different depth ones for the 9two5 and the evo enclosure.
I’ve got a switch 40 that I can use to make an enclosure for that one but it’s pretty low.
Itching to make one for one of the shorter decks for a light commuter with a kick tail.
From my side… I’ve been sooo busy with life that this has slipped out of my mind.
I’ve not had a dingy to hand though to make an enclosure.
If one came along I’d make one for it.
