maybe i should order a set and figure out how to pulley them.
Well the only hub motor designed around the centrax (and comes paired with the centrax for front wheels) is hummie’s hubs. Excited as motor assembly is well under way! Had a few kinks to work through with the assembly, but all motor assembly bugs have been worked out, span the first of many assembled motors a few days ago!
I agree, the centrax have a great grip to and riding feel!
Hub rides on it’s own bearing. Solid core drilled and bolted to the hub.
centrax wheel has a center line bearing pick-up point. It really will crowd the pulley area being a center mount wide wheel.is that RB I? or RB II…
I like the way the gear and pinion sits inside your rubber race wheels though, & no one else is getting the gear reduction you are MoeBro!
I wish abec11 made there way down under more often, not normally available at my locals…
sounds like a job for a drill press and a bit of jiggery.
? 10charss
So tldr: We gots a millionaire who can’t takes photos of himself
We have a company who “claims” the world records but has horrible customers service and crappy engineered parts that will melt.
Several boards go 50 mph regularlies and work without melting
LHB did right by his customer whiles NGV became a ghost.
The world record is about having $$$$$
