I feel the same way. It seems like so many careless about their customers and more about their bottom line.
If NGV wants you to pay half, their are STILL profiting on the replacement… That’s shameful. You sell a product, it fails, and you offer a replacement with a profit margin for yourself still?
My dad taught me one thing (and only one thing, lol) as a kid, and thats “The customer is always right. Even when they are wrong”. It’s time for the industry to learn.
The only times I’ve ever seen or heard of them running was when they broke.
World record run: wheel came off and crashed at the end
This guy: Motors and whatever else burned up and out of service for months now
I’d love to even see a board go from 0 to 40 and back to 0 again, I wonder if I can build my own board that does this before I see proof of even ‘basics’ with a NGV!
Jake does it all the time. I build boards regularly that will do 40 with no issue provided the gearing is set up right. I prefer not to recommend those speeds, however. they’re not really that practical in every day commuting or derping, and it takes longer to stop and increases the risk of over current while braking.
I’m tempted to offer the customer an all wheel drive belted system with larger motor pulleys if they keep fucking around. Hitting 60 is just math. there’s no reason a belted system can’t do it. You just need to manage expectations for launch and use the right ratio and wheel height.
That’s what I’ve been saying. Their system is based on bad math. They project insane top speeds but forgo proper gearing for low end torque.
Then there’s also the the shit choice on wheel design (I mean compromise) so that they can have the aesthetics even though their wheels fall apart at the speeds they want to do.
I don’t understand the reasoning for using hub motors for high speeds. If I really wanted to hit 60 mph, I think the most reliable option would be 4wd, with 6-7 inch pneumatics using a 16/36T gear ratio. That way when I wanted to just ride normally, it’s as simple as swapping the wheel pulleys.
On that note, @psychotiller if you want to break the top speed record with one of your boards, I’ll jockey it for you
A major part of the purpose behind having cored wheels is to insulate the thane from the heat that can build up in the bearings at sustained high rpm’s.
AWD superfly build on a 23/33 motor to wheel pulley ratio at 12S on my motors and focboxes on li-ion will do it theoretically in a full tuck using a 130 pound rider or thereabouts.
But manage your expectations for launch and braking. I’d also probably go with ceramic bearings, and refresh them with every speed record attempt. Probably do new wheels as well.
I have no interest in doing any of this, its not what i’m after. But If any of you want to, that’s the approach i would likely take.
Had my Centrax over 45mph. They are quite lovely. Think I would set-up superflys for 70mph and spin em up on the bench and look for growth and distortion. That is a chunk of urethane right there. I’d rather be on a proven purpose built wheel.
