@treenutter its also note worthy that this black metal scarlet build doesn’t need to be charged. It simply feeds on the souls of the animals it crushes under its wheels for its hellish performance characteristics.
very nice build. can totally see the dedication and patience of making the deck layer by layer
Thanks bro. I spent almost a year developing my press and process. I’ve got it down to about 2 total hours of labor per deck at this point. Gluing and tossing in the press is about 20 minutes, cutting, sanding and drilling truck holes is about an hour and a half-ish. There’s a few of these Scarlets in the wild now, and the reports i’ve received back is that they’re just as tough and take as much or more abuse as factory decks.
I built the first press…
and then i built the one i’m using now because the first one broke:
Including the cost of the mold and enough veneer for 10 7ply or even 9ply decks, this can be done for less than a grand. I spent a tad more than that because i was in uncharted territory building my own press instead of buying one for $5000, so i wasted some veneer and obviously an entire press’s worth of wood and hardware when it exploded making my first successful deck pressing.
What does the “trick” (cutting 18mm off ea side) do?
makes room on the hanger for those press-in pulleys that have their own bearings. The trucks on the Raptors have been modified at the factory for the Raptor’s injection molded pulleys, and Evolve did something similar with theirs. If you want to use either one of those pulleys on regular caliber ii trucks, you have to take off some aluminum.
such dedication, bro! unfortunately i live in a place where i do not have such space at home to do anything as massive like u did
seriously man wish I had the space for a shop!
my truck is permanently parked under a tree in the driveway now. I have half of the garage, my wife has her car in the other half, so my actual workspace is about the size of a spare room. Also i share my half with a washing machine. It’s full of compromises but any good deal is. So far it has all worked out really well though because the things that were scattered all around the house are now in one place, and all of it is out of reach of tiny hands now.
workshop looks great now!, love the led strip lights, extra bench space is like a breath of freash air…
MOAR CELLS the 18650’s for the 12S build arrived, this time in high performance glossy boxes instead of the regular old not glossy ones. lol
AND SUPERWORM! I love this shit. I got like 80 feet of this shit between the 10awg and 12awg total. Best wire ever.
and finally… this came in the mail…
so i can’t wait to see what these wire channels are going to look like with this gorgeous clear resin filling them. Also going to be building the boxes with this stuff until i run out, then i expect i’ll buy more if i can’t get somebody locally to start building my boxes for me. I don’t think i can fab my own boxes forever, so i may have to settle on a design that can do up to 12S4P and then use it for 10S builds too.
Did some of this last night:
so i could make these:
i numbered the balance points on the cells and soldered in some balance leads. i used a paint pen to add on number of dots to the leads in two locations so i would know which was which. Those are 8mm strips, i didn’t think that the 4mm strips the welder came with would be good enough to channel all that power Hail Skatan.
then I shrink tubed them:
the paint dots on the leads worked out. I can clearly see which is 1 and which is 12. I still have to solder in the big wire jumper between groups 6 and 7 and also solder in the mains and fasten them down. I ordered a roll of that wide shrink tube but its probably not going to be here on time, so there’s going to be some taping.
As soon as the BMS and VESCs arrive i can start making a form for the box. For now the plan is the make it very thin until it gets toward then end of the pack, then i’ll have it ramp up in space so that the BMS and VESCs can have some room.
I’m not sure where the fuel guage is going yet. I sort of want to put it over the front truck so you can look down and see it.
If 8 isn’t enough let me know now, i can still tear it open and double up the strips. I thought it would be though.
did some more digging. Looks like people are saying i need at least 10mm on there. things i had read before said 8 would be fine. I’m also seeing more and more about people using 15mm like was just mentioned here.
I think i’m just going to open the packs back up and add another layer of that 8mm nickel to share the load to be safe, that should be effectively the same as having used 16mm from the start. I’ll have to redo my balance leads but whatever. I don’t want to take any chances.
I love how one day you look something up and see one thing, then the next you see something else.
TBH, I think you would NEED at least 15mm. On @whitepony s builds, on the outer connections he uses 15mm nickel + braided copper wire to connect the long serial connections.
i’m planning on joining the two packs with 10awg superworm, the same thing i’m making the mains leads with, and i’m definitely doubling up that nickel tonight. I may even solder along the edges of the two strips to join them better after i get the second ones on.
Haha, Hail Skatan. Nice!
Looks great except for those slow ass BLUE motors. Lol. Any way to redden those up?
Gorgeous and quality build LHB - as usual. I always get a laugh on your posts and some serious dedication building this! Shop is looking great - congrats!
Those SMD LED’s are awesome! I just did some over a workbench in my office as well. The new 5630’s claim 25 lumens per LED - about twice as bright as the last ones i got.
I’ve found soldering before mounting is helpful, but i have done it upside down before i learned…
i did cheat a little and tin the terminals and wires prior to hanging the lights up so then i just had to stick it for a second and tape over them.
LOL i’d have to tear them down completely to strip the anodize. I’m not that brave. I know they come apart pretty easy but i wouldn’t want to introduce any additional chances for failure by doing so, at least not without trying it out first on my rat board. I have no idea what greased lightning would do to the magnet glue or epoxy or whatever is holding them in the can.
So i guess i’ll just have to take the performance hit and explain to the customer that this board could be faster, but there’s blue on the motors slowing him down a little.
