If I have 4lipos to create a 12s2p pack, would it make a difference relating to voltage sag and battery temp. if to power 2 vescs with 12s2p or twice 1 vesc with 12s1p?
Assuming you will be running a bms, 12s2p is fine, but itās best if youāre using high quality lipos, preferably with matching ESR values, and before you connect the cells in parallel, they need to have identical voltage. 2x 12s1p would need two separate bmsās I believe, and two separate chargers. Itās a bit complicated either way, but 12s2p may be the simplest way.
Edit: in either configuration, the heat and strain on the batteries will be less
Thought about 4 of this one, as they ship international
Balance charge them with a imax b6 and just connect when fully charged.
can you say me what could be the max voltage difference between the cells if to hook them up parallel.
I plan to go quad MTB. So the easiest way will be to run twice 12S1P, right?
You thing a BMS is needed on the board too, if I balance charge them? I know there can be a disbalance because of different load and reg. breaking, but that should be not that high that a balance charge after can fix it again. Or am I wrong?
Just started with the LiPo topicā¦need to get more information
This is a good place to start with Lipos: https://rogershobbycenter.com/lipoguide/
You want the voltage difference between parallel cells as close to 0.00 as possible, as they will attempt to equalize at an unrestrained amount of current, which can be hazardous depending on the difference of charge.
For the best sources of information about lipo batteries, I recommend the various rc-hobby forums, as they often have been around for several years more than this one. Additionally, they tend to use lipo batteries exclusively for the power to weigh superiority. Not that this forum lacks in scientific talent by any means, but the rc-hobby groups seem to attract more, as not every geek is thrilled about skateboarding. I really mean no disrespect to our forum, but itās good to look around for an enhanced degree of perspective.
Just food for thought.
do you have a recommendation for legit lipo seller who also ship international?
From my personal experience, Gens TATTU are likely the best option available. However, their batteries are very expensive. The packs Iāve been running for a year and a half are still in remarkable shape even after over discharging them (by being an idiot). Second best option seems to be turnigy graphene. These are from hobby king, and from what I understand, you can demand that they sell you āmatched packs only or no dealā!
The most important bit of advice I could give you is to do tireless research. Inquire with sellers about matched cells and etc. It NEVER hurts to ask for the best option they will provide. Get a Wayne Giles ESR meter, and you will know exactly what they sold you. Ask @deucesdown about the device, he convinced me to get one and I couldnāt thank him enough
Hey @PatRocks youāre awesome.
The more I read and the more I hang around here, the more I flip flop.
Despite the deserved reputation for higher quality and safety of the individual cells, seems like most of the recent battery fires are 18650 builds, and most likely the reason is there are just soooo many connections, so there are soooo many places for things to go wrong. In this respect lipos have a big advantage. Hooking up a pair of 6s1p in series, or even 3 x 4s1p in series, using the provided connectors, removes a ton of variables.
However, most of the lipos we get a look at are oriented toward hobbyists who want cheap and powerful. And the design is to run for 10-50 cycles.
Regarding, quality, industrial lipos are probably much more carefully built. Like the GensAce Tattu line @PatRocks suggested. Iām thinking, manufacturerās reputation is probably the best thing to bet on. If they can be sued or will go out of business if their lipos catch fire, theyāll be a lot more careful with the build. But, even the top tier mfgs seem to have spontaneous fires! I remember reading a story about a fresh Revolectrix pack catching fire on first charge.
For safety, most likely a high end hobby charger (non-parallel charging) will be safer than BMS. Mostly because you can see whatās happening. But itās a pain in the balls if you charge every day. @PatRocks sidesteps this by building enough watt-hours to charge once a monthā¦
Seems like the only reasonable way to stay safe is to monitor your pack. Total capacity, internal resistance, how balanced does it stay, how well it holds charge, temperatures, mechanical abrasions, etc. And stay close when itās charging.
I know Iām probably on the wrong side of paranoid, but everytime I see a story about battery problems, I try to think, what could i have done to prevent it, detect it, mitigate damage, and also what could I do as itās happening. The most recent story makes me think I need leather gloves and a fireproof blanket near my e-boards, and a gameplan for moving it outdoors while holding my breath.
All in all, lithium ion and lithium polymers are pretty darn safe! So itās not so much the chance of failure, but the consequence of failure, that drives my paranoia.
Here are some links for your pleasure.
https://www.rcgroups.com/forums/showpost.php?p=15776103&postcount=4
http://theampeer.org/Learning-LiPo/Learning-LiPo.html
https://www.mpoweruk.com/failure_modes.htm
I guess I should note, usually I charge my board with a bulk charger or CC/CV supply, set to about 90% of full charge voltage, on a a/c outlet timer, running though a volt/amp/watt meter with a time display. I try to be near the stuff when itās charging. I see how much energy goes out via ackmaniac app, and i can see how much goes back in. Iām commuting so this happens twice a day.
No bms (but Iām warming up to the bluetooth bms for charge only ā very attractive little units, $60ish and you get a phone app where you can see individual cell voltage, can be configured for like 10s-15s)
I tear down the board and use hobby chargers to cycle test the pack once a month or so.
Prevention is always good and never enoughā¦ I donāt think itās a paranoia. Just some people worry more some less. Both can be lucky all there life but if something goes wrong only the prepaired ones can minimize the damageā¦ If you think about to get your burning board out of the roomā¦donāt forget to buy safety glasses. You donāt want to get hot rubber flying into your faceā¦ I know what iām speaking about, I had experience with a burning board just some days agoš¬
Right youāre one of my inspirations. Iām thinking, based on that reddit video I linked, thereās no time for glasses, probably not even for gloves.
Open door, hold breath, throw blanket over, give it a hug and run, take a few burns and bruises. Then fire extinguisher for inside if needed, water/sand for board if inside is under control. Maybe?
EDIT and pliers for the loop key
EDIT EDIT one of the things Iāve learned from everyone posting their experience, and my own experience. Itās when we want to just try it after completing a big stage of the build, that terrible things happen. Must be patient, and stay safe.
My advice, find a workplace where you just can let it burnā¦and which is easy to cleanš Took me fā¦ 4 days to get 90% of the dirt out of the flat (including professional cleaning help). Still happy that I was prepared.
I already ordered a new pack of 18650 before that sh.t happened. I already had plans to make the new pack more safe. Cell level fusing, fuses, powers switch and bmsā¦and wanted to redo the old packā¦I think sooner or later iāll built it, but definitely not in my home.
Iām now on the point where I think about LiPosā¦ Started to researchā¦and think how much they more or less dangerous. My next built will be a mountain board with the batteries on the top, so the size doesnāt matter.
Maybe you can say what you think about my first thoughts. I plan to run 4wd 170kw 12s Powerd by twice 2x6s lipo (the heavy duty 5000mah 60c I linked in the post up) So the max battery output shouldnāt be more than 60-80a for one 12s pack. I thought about a12s2p pack to power all 4motors with one, but I guess the parallel lipos need a bit more attention. I plan to buy two imax charger (no fakes) to balance charge the packs. No bms on the board
Any thoughts on it? Something else I should look for?
I looked the tattu lipos also but i couldnāt come on there website as itās under construction at the moment.
SOS @Cobber
At those loads the 10awg wires start to look too wimpy, XT90 looks wimpy, etc etc. And if you think about 80a -> 5ah pack, youāll get what, 3-4 minutes out of it? I think youāll need to scale everything way way up.
I donāt think I can get more than 30a constant for each packā¦ would be crazyā¦ donāt wanna fly to the moon 80a burst for 3-4sec. guess even not that With 4 motors more isnāt even rideable Xt90 can handle 80a, 10awg 55a think the set up is not so bad With the 4blocks 5000mah as 2x12s1p I should come around 15-18km. Not only 5min. Most time itās flat surface where I drive. Some hills, a bit off-road but no Mount Everest. And I donāt weight 200kg
My thoughts are that if you are planning to lay down the cash for a 4wd build, then why not spend extra on higher performance batteries? The hk graphene 6Ah 65c packs are really REALLY killer batteries. The ones that Iām testing are showing a safe, sustained 180A discharge capability. The rcgroups guys are getting more than a thousand cycles on their packs (smaller capacity, but shouldnāt be any different for larger packs) , but thatās my two cents. Donāt bottleneck your build at the batteries!!
Also, the "C rating " stamped on the label is not a true story. However, batteries sold as high-c rated are likely to have fairly low ESR levels, which is directly related to the voltage sag you will experience under high amp loads. The ESR (equivalent series resistance) is ultimately the determining factor of battery performance.
The point Iām trying to make is that voltage sag is what you (edit: want to )minimize! But Iām a shameless hardware geek. It just seems that if 4wd is the plan, then obviously money aināt a thing!! Right?
testimonials are from the regulars at rcgroup.com. hmmmmm! Maybe itāll make the 65c black&red ones cheaperā¦
I saw these two weeks after buying 4x of the 65cās
At least I was able to get them cheap (fatherās day sale and 10% new customer discount) paid $380 for the set
Damn, and thatās your baby pack lol
Lol, yes it is. My plan is to deconstruct the packs to slim the whole thing down and connect as 12s2p with the DieBie bms (80a fuse bypassed) monitoring the powerplant. Should be a good time.
@Andy87 which ever path you take, I think you will be pleased with the results. Like @Cobber said, the helifreak forum guys drain those turnigy HD packs in ~5min. with no drama.
Very eloquent @PatRocks. Well said.
