I’m a keen snowboarder, Brit living in the French Alps for almost a decade now. Unfortunately I only bget to do this 4/5 months of the year and get massive withdrawal symptoms, until I discovered Electric Skateboards.
After 3 months of soaking in the a vast amount of knowledge, advice and and opinions on this forum I’ve started on my build. Before I get started a special shout out to @Nowind on hisawesome Mini Direct Drive and @Eboosted for the sleek enclosures he makes, and both for the build threads they have posted on here.
Anyway, here are the guts and all of the build.
Tramp HS11 Deck
Eboosted enclosure
Trampa 6.5" AT Superstar Wheels
ETOXX Mini Direct Drive Black edition
Trampa Vertigo Trucks, (Rear Hanger Machined by @Nowind )
Dual APS Alien 6374 170KV motors
12S4P Battery using Sony Konion VTC
Dual VESC6 esc
Supower 12s 60A BMS
charger 2 amp, 12s, 50.4V
NANO-X hand controller 2.4Ghz
BT UART module
I really pounded these APS 6374 170kv motors at 12s for months without any issues, they are amazing
Amazing build man, it’s definitely the next generation Pho3nix, the grip tape, the direct drive and the battery boards are sick improvements! Can’t wait to see it finished, you will love the ride
Hey guys, little advice needed on soldering 12 gauge wire. I have put the solder spots on my PCB holders, solder on the wire itself. When I come to soldering the wire to the solder spot on the board it is not holding. I’m a novice when it comes to soldering, but have watched a few tutorials so not sure what I’m doing wrong. I’ve attached photos of solder I’m using, solder iron etc. A couple of connections have worked but it’s a real struggle?
What power is the soldering iron? Doesn’t look high enough, you need to be able to heat more of the surrounding metal to get the solder to flow and adhere better.
Would recommend getting some flux; as in the tub of brown gooey stuff. I know the solder has some small amount in it already, but I was amazed by what a liberal application of flux would do.
Flux is a good idea, and you may just need to hold the tip on it for longer.
You can usually tell when you’ve got a good solder job, it flows different to when you have a cold solder joint.
