I’m about to start a build using 2 FOCBOXs (bought when they were still VESC-X) and I intend to run FOC. I’ll be using a 10s3p pack and dual 190kv 6355 motors and limit current at 40A (20A each). I’ve searched the forum and there’s not much info on people running FOC with Enertion’s FOCBOX. I’m hoping experiences will have been positive. I mean, FOC is in the name of the product!
So can you chime in with your experience running FOC on Enertion, both good and bad?
ill let you know my focbox’s should come sometime next week to replace my old enertion vesc’s, i have a raptor dual which is identical to your build, i want to try FOC mode too.
I’ve heard from a couple people that it’s “FOC-proof” and has a transistor that shuts off before anything can burn the DRV, but I’m not sure about that claim.
I had an issue yesterday, one Focbox could not make motor detection and threw an ABS overcurrent fault. So instead of burning the DRV or shunts some audible “clack” noise maybe some kind of thermoswitch activated and prevented the Focbox from frying.
This happened while runing as well. At the end the issue was a faulty Focbox, but just to confirm there was indeed some kind of protection that saved the DRV
nice to know, though still sucks that it can potentially shut off mid ride, but I guess it’s good for people to see if they can even run FOC on their setup.
Well, this protection is nice but yesterday I had a fucking scary nightmare, when I went to test the board, I gave it full throttle and the protection activated, this caused one motor to kept spinning for 3 seconds, it pushed me sideways, even though I left the throttle go, almost loose control buy fortunately was able to save it.
Nothing is more scary than being riding a board at full speed and not only loose your brakes but lock one motor at full throttle for the longest 3 seconds of your life
Wow that’s crazy and seems like a huge design flaw. VESC should never lock at full duty cycle… I’ve seen some crappy remotes do that, but haven’t heard of the VESC doing that. What remote were you using?
I was using a mini remote, but that was not the issue I can definitely confirm the bad FOCBOX locked on full throttle, I also replicated that on the bench.
After replacing the Focbox with a spare one the lock didn’t happen anymore
It seems that @Eboosted had a faulty FOCBOX; so hopefully it was a manufacturing glitch and not a design flaw inherent in the product. Is that your impression @Eboosted ?
I suspect that FOC reliability is heavily tied to eRPM, which would be why people running FOC on hubs don’t have any issues. At 10s w/190kv motors you’re running at about 45-50k eRPM after inefficiencies.
I wonder if I’ll counter problems when approaching 60k on my 230kv 10s board. I hit about 55-57k erpm on this setup.
