Looking through the https://www.electric-skateboard.builders/t/eskate-lights-thread/199/354 there are tons of different ways to achieve headlights. Though whats the visibility range you all are getting? I’m looking to purchase some lights but I need a simple setup with far throw say at least 20ft due to the trails I ride at night plus its just gives you a bit more confidence when riding at speed.
Recently I purchased: https://www.ebay.com/itm/SolarStorm-15000Lm-3xXML-T6-LED-Head-Bicycle-Bike-Lamp-Light-Rear-Light-16000mAh/322656749160?ssPageName=STRK%3AMEBIDX%3AIT&var=511675710648&_trksid=p2060353.m2749.l2649
which I really like, comes with a 4 cell pack and all metal casing plus it’s super bright and has a decent throw of about 15ft mounted underneath and three brightness settings. Problem is that is will require some effort mount. There’s no clean or easy solution. I’ve learned that these lights have to be extremely well secured or they will vibrate loose, so I’ll have to design and 3D print something which will take some time (on the plus the electronics are super simple).
So what kind of illuminated range are you getting with your setup? What are you using?
