I’m form Spain and want to share my experience. After reading and reading y i feel (almost) ready tu build my own e-board.
Thanks to everybody in this forum!!
I have learned a lot here but I need help with batteries and charger.
PARTS:
DESK: I’m going to use my cheap longboard (Madrid Weezer)
MOTOR, TRUCKS, WHEELS, MOTOR MOUNT: Enertion kit. I think motor is 190Kv
VESC: from esk8.deREMOTE: Niko Kama
BATTERY: [Zippy 5s 8000mAh] (http://www.hobbyking.com/hobbyking/store/_38302__ZIPPY_Flightmax_8000mAh_5S1P_30C_EU_Warehouse.html) x2. 10s in serial
CHARGER: I don’t know. Could you help me please? Something about 40€ would work?
How should i charge the batteries? Could I charge both batteries with the same charger? I didn’t find posts with tutorials about it.
Of course, I want to make it safety, so i have this link to make a loop key. I’m not sure what it does. Prevent Sparks? What sparks? when turn it on/off? I need something more to make it safety? EDIT: I must add a fuse too?
I’m waiting for parts to arrive. Thanks to you again!!
@ArmandR De precio está perfecto! Sabes si con ese cargador puedo cargar las dos baterias en serie a la vez? O cargo primero una y luego otra?
Thanks!!
When you will plug in a >6S battery to an ESC the capacitor will load instantly and that results in a spark. To prevent the spark we put a little resistor between the battery and the esc that the capacitor just loads slowly and no spark happens. Otherwise you will fry your key over the time because it will destroy it with every spark.[quote=“raxell, post:1, topic:5237”]
[/quote]
You dont need to but it is much safer! If somehow your setup should draw more than the fuse allows it would just turn off. You will need to replace the fuse then but the over current do not destroy your esc. That way you can buy a new fuse and safe a complete esc.
Yees!!, finally, after two months I have my enertion parts.
All it is working:
VESC OK
Motor detection OK
BUT!! my Nyko kama don’t connect. The red light flashes and turn off. I didn’t try nyko kama before in a wii so I don’t know if it is broke or if I have to do something to turn it on.
Maybe I have too long cables in the receiver?
I’m going to show my VESC setting. I could not ride it yet, I need nyko kama connect with the receiver and I am working in the enclosure.
Are my setting ok, please?
I don’t want hard brakes
