Thanks Frank, I’ll take it handy, note I have a real Holeyif it all goes Pete Tong. Toying with the idea of putting it on a little compound table but it’s too big and heavy probably
Stil slow progress, pack is gettin there, name change, all my builds will be under the pseudonym ‘Magharees’, in fact I’m going to namechange if possible
It’s 2019, hat much further along? Practically zilch, I found a little time today to cut the deck. I’m leaving it like this and not channeling out the bits at the top of the truck.
Apart from that everything changes
3DServisas v2 5:1 drive, FatBoy 9” wheels, MBS F5 straps and an Idea undertray with a 12s4p of Sanyo 21700B, a DieBieMS and hopefully a Unity (grumble). Motors just what I have which is a pair of APS 6380s 190kv. Completely underpowered, as its wrong kv for the wrong pack, will address that as needs be
Was that the 35 long which you cut down? I decided to move my truck holes down too, felt they were too high up.
I’ve got a jig on Thingiverse if you’re interested.
Thanks mate, yeah I stole your jig and printed it already but iirc it’s for the diddy mini trampa basepate?
Actually nah they have the same holes apart fro the inner spring position on the mini.
I’m all good thanks. The deck I have uses the outer forward holes which I’ll use since this gives more strength, I’ll use your template to drill the rear ones though, for some reason they are not there…it’s an old deck
