Hi, I need to get a motor mount but are already over budget by a lot. How can I make a motor mount cheaply!
product/welded-motor-mount-63mm-motor/
Buy this an weld it…
The clamping option is not much more…
Not sure how “Cheap” you mean
Is 50mm safe to go with?
Check this.
Don’t have a drill press
Looks like you can’t make one then.
You can use a normal drill. just start with a small hole so you can get it lined up correctly, then gradually increase the drill bit size.
Also, 50/63mm for that welded mount refers to the size of the motor.
Sure…ntm 50/60 is a main stay…but would suggest moving to a 63 can size
you really dont need a drill press! if you have a good bench mounted vice, a hand drill and some little rounded files and fat ones youll be alright
The only part you will need to drill dose not need to be square just yet
scribe out what shape you want then drill atleast 1mm form the edge so you can fix it up with files later on if you didnt get the drilling square
my final product
Or make one from carbon and resin with a mold
Mold 25$ Resin 25$ Carbon 10$
Or do a mold with expanding foam and traditional carbon layup exoskeleton
Or get your trucks with the wheel and wheel pulley on, and your motor with its pulley and the belt, hold it all in position and get someone to put epoxy putty everywhere it needs to go. No ones tried that yet I don’t think.
Or decide it’s too hard to make a mount and make a hubmotor.
if you want a really cheap motor mount you need only Z or L steel bracket(2-3$) and 4 screws with self-locking nuts (~1$)
Most impressive motor mount yet! How does it hold?
DUDE!.. now that’s fucking impressive… love your “I don’t give a fuck about aesthetic” attitude…
Next, I want to see someone make a motor mount from an empty Pepsi can!
That is Ghetto Fabulous
How does this hold up?
What size would the sk3 245kv be? I must be stupid because I can’t find it
What’s the size of that aluminum block you have to make that motor mount
I’m making mine from a scrap piece of 6mm x 50mm Aluminium that i got for $5. It will be enough to make 2 mounts, if need be.
