I have a 27" (Amazon nickle board)and will be making it into an electric skateboard I won’t be going at high speeds max 20 km/h (12.5 mp/h) my main goal is to go up steep hills so I will be using 59mm wheels and a 3:1 pulley ratio (280kb motor) just want your guys thoughts any tips or comments in general#
Think about how you fit a pulley on there. Most pulleys would already be as big as the wheel. You might be able to get it to work with a chain drive though. I don’t have much experience with chain drives, however.
If you run 59mm wheels, you’re not going to be able to run a large wheel pulley. If you don’t run a large wheel pulley you can’t get a good reduction ratio down to motor pulley for the required torque you want for steep hills. The smallest pulley I’d ever consider running on a motor would be 13 for a 5M pitch. Any less than that and you’ll have issues with slipping. If you’re hard set on tiny ass wheels, then move to a 3M pitch.
36T HTD 5mm pulley has an outside diameter of 56mm. That’s not including the belt. With a 59mm wheel, the belt would basically be scraping the ground at all times
Yeah I’m not going to answer that question because clearly you have not done much research on VESC and BLDC tool or VESC tool. There is a whole category dedicated to VESC and also BLDC.
