Mexican bull / comp 95 / 12s /focbox unity
what should I do, use the pelican 1200 or make a wooden box
Pelican. 100% waterproofed
+1 for pelican. Sturdy as can be. We use them for work.
And for the focbox enclosure
finally I think that this is going to be the design of the motor support for the matrix 2image
the motor assembly is ready to install the two 6374 engines image image It will break?
I think you’ll probably need to double-up the cardboard for it to hold.
Some paper mache over the top might help to add some extra structure, maybe add some elmers to the trucks as well before you slide on your mount.
You can use ketchup in a pinch.
I was thinking about adding carbon fiber vinyl to see if it stiffened more the structure of the mounts
That’s smart. Don’t forget RGB lights as well for extra speed. But really though, excited to see a Unity in this beast, mounts look neat they will be waterjet aluminum or machined?
Don’t forget spoiler it adds 50Nm more torque to wheels
machined by a friend in a lathe
I think in 6mm Aluminium plate for the mount and 12mm for the clamp
You also was thinking about riding a Tiburon’s mandling that I have at home in front to be more than aggressive
Yeah, that sounds sturdy. I think I might pick up some matrix II’s when they are back in stock so I’ll be keeping an eye on your mount design. Have a lacroix deck sitting neglected hoping to find the time over the holidays to give it some love.
some time ago I found this on facebook I think it would look great89E7008F-4D22-4F09-801B-1BA3DBFCA25B
Just need to buy the new $1000 vesc:
10mm or bust
