I would use a FVT 120a ESC. That one you can also order from Banggood.
You should also be aware that these motors do not fit most of the common used motor mounts. You will have to make your own.
Anyone have any update about these motors. I just ordere a 6368 280kv from them. I really don’t know how this motor will work with my 2 to 6s goolrc 120A esc. I am only running a 6s battery. Maybe I should have order a 5065 200kv instead.
@paragon I actually wanted to create a similar topic and ask if anyone has tried them yet? But gladly, the search baloon opened and showed you have already created a topic for this!
Anyways, price looks really good, considering they are also sensored… just hard to tell what the customs fee might be… if it does show up…
Too bad the 63’’ ones does not come with lower kv… Though, these 5065 looks like could be a really good solution for low cost dual drive
So yes - if anyoe has them, could you give a review?
Interested in - are they reliable, are the bearings / shaft in similar quality like sk3?
Still no reviews? I found them on aliexpress… where it seems like the same (one) seller is selling them through 5 different shops of his… (the text desciption in all the listings is the same)…
I got a few of the 140kv motors in the 5065, all of the plugs and dimensions are exactly the same as the evolve motors. I haven’t tried them on the board so cant comment but visually identical.
uh, if they are quite the same as evolve… then I believe evolve is charging at least 100 extra for each motor The power of branding and your own company I assume
Ahh ok, is that what the smaller multi wire plug is for? the small white one?
Sorry, i’m pretty new to this stuff! but yea, dimension wise and materials wise they look identical
