I am using Caliber 2 trucks on my board and have a problem:
my motor mount (that I made myself out of a 1cm Aluminium plate) keeps “moving” closer to the wheel after every ride. I guess it is due to vibration and have already tried to put some shrink wrap over the truck to allow for a better grip of the mount but had no luck.
Should I just add more layers of shrink wrap or do you have another idea? Grub screw maybe?
My caliber trucks are also slightly conical towards the wheel (as in: they get thinner) which does not exactly help
Your safest option would be a grub screw. It would be my favorite choice. But be careful with a grub screw because it could fall easily off. It did happen to me on a grub screw on my motor due vibrations. I just put some glue in it and it did not fall apart on its own yet. Another option would be nail polish. Sounds weird but it is like glue. Just not that strong… but it is enough.
Use threadlocker to keep the screws from vibrating loose. (They will do it)
Use the blue (medium strength) if you plan on wanting to remove or adjust them at a later date.
Red (high strength) is pretty much permanent, so be sure you place it right before using that.
Cool mount, you get maximum amount of points for DIY spirit.
There could be two potential issues: the mount is not strong enough, bends and gets pulled towards the wheel
or your clamping area is not precise enough to have enough clamping force. Maybe a mix. Difficult to tell from here.
The grub screw will help if your mount is strong enough.
I can almost guarantee that the clamping area is not precise enough
Doing it by hand with just a file I was not able to align the edges perfectly - so I really hope the grub screw works.
