Firstly like to introduce myself, im Jake and im new to e-boards but im a maker so i decided to build a custom board.
The board is built and works great but the issue im having is that the batteries run out after only like 500m of riding, basically to the end of my road and back a couple of times.
I have dual motor and using the followowing
Motors
Batteries
Vesc
I’m new to the setup of the motors so any advice on what the parameters should be.
Pretty straight forward setup,
batteries to vesc’s via diy antispark switch to motors
Been doing rc stuff for 10 years. Ask a trusted lipo user around here and ask them if 3v/cell is good for longevity or not. As said earlier, 3.6-3.7v/cell is optimal for longevity. 3v/cell is way to low especially for hobbyking lipos…
Well when riding a board, the batteries are cleary under load. The board wont cut out before 3v/cell with the settings you suggested, and by then the lipos would be damaged.
The battery he states might be a issue it’s only rated for 62a and turnigy usually overrated their battery, would recommend 20c at least and 30c to be safe
Well you wrote 3.2v for cut-off start, and 3v for cut-off end earlier. Even if the load isnt at max, there clearly is a load. Sure that the lipos Shouldnt be damaged before 3v in theory, but I am talking from real life knowledge of hobbyking lipos.
My lipo is over a year and a half old, cutoff is alawys 3.0v with zero issues, it’s s bit puffed but Its to be expected from a year and a half old lipo
Also charged at 1c the whole time
But my point was lipos won’t be damaged untill 3.0v and I’m outta here
I dont know man… You keep changing between 3v hard/3.2v soft cut-off, and 3.2v hard/3.5 soft cut-off. Either way, you are talking theory, I am talking real life experience.
