Guys, have anyone had issue where the remote shows ‘binder’ with a solid green, but it doesn’t send any signal out?
I have both the new and old receiver and remote, sometimes they connect, sometimes they dont, but no matter how many times I have it connected, it won’t send any signal when I pull the trigger
I’m sure the motor is fine because I can run the motor detect perfectly, meaning there is power sending to the motor when I do it through bldc, but the remote has no respond… I’m sure it is connected though, it gave me solid red on receiver and slid green on the remote
Are you plugged into channel 1? Most RC receivers use channel 1 for steering. The nano x is built for skateboards specifically. So the primary channel is the throttle. Just asking and hoping to help.
hey there
i got signal going now
but idk why, when i pull the trigger, it goes full throttle
and when i let go of the trigger it just keeps running at 100%
and unless that i pull the break, it wont stop
when i left the trigger at neutral, it seems to give out 100% throttle
im not sure how to configure this XD
so basically the motor only stops when i pull the break completely
when i pull the break a bit, it starts to move (as if i pulled the trigger going forward)
and by the middle, where it is neutral, it is running at its 100%
anything after the middle stays 100%
can anyone tell me how to configure this properly on the bldc XD?
i kept tweaking with the Y connector i had for the dual motors and receiver
and it randomly worked… but it was like half an hour of tweaking here and there, not really sure which part exactly did i made it run…
but im still stuck on it running at 100% without me pushing the throttle…
