With everything working what is your Range?
Around 20 if i take it easy maybe 25
Yeah, I linked that already and it said his range should be more than 30km.
Sanyo NCR18650GA 3350mAh - 10A
The Panasonic ones are a lot cheaper. € 2,55 VS € 4,00 2900mAH vs 3350mAH
@moon Your Sorce looks like US
I will set my cutoff at 28 v and ride it till it reaches 28v and see how much can i get, but thats going to be hard since my legs start hurting
Anyways that board is waiting its finishing touches and is sold to a much lower less requesting customer, and also like 30kg lighter from me
TBF I am a noob with batteries
whoa Thats Strange Why write prices in Usd then?
IDK but he does say
Cells are located in Europe. No fees to EU countries.
OK then the Panasonic cells from your cool source are,
2,19$ vs 3,69$ 2900mAH vs 3350mAH
Edit: OPPS the 2,19USd cell is Diffrent.
What Panasonic cells are these?
I am noob as a said
There 10a 18650 cells But have lower capacity But the watt-hour per doller is better. Panasonic 10.44 WH vs the sanyo 12.06 WH
My bad the cells you Linked might be better valued.
I think they are slightly more expensive. Where are those 2,19$ cells?
There only 6.2a Not good for esk8 But I see nice SONY NC1 2900mAh - 2,09$ each But If it’s not a trusted source they could be Chinese fakes.
Your space req’s: - 23.5 \ 18.5 \ 7 CM
referance LiIon 30Q: - 3.6 * 10 * 12 = 432WH 20A discharge (80 in 4P)
Zippy compact 5000 5s (X4): - 16 \ 3.8 \ 4.6 10s2p Zippy Compact 5000mAh - 3.7 * 10 * 10 = 370WH
Zippy flightmax 8000 5s (X4): - 17 \ 3.9 \ 6.9 10s2p Zippy Compact 8000mAh - 3.7 * 10 * 16 = 592WH
Oh you are looking at the endlesssphere post
