inspired by @GrecoMan and @florr
Iāve been half-heartedly āgetting into Blenderā for about 8 yearsā¦ T_T
I didnāt have the motivation until I realized my motors are waaay too long for my generic trucks =P
One thing to improve reliability is make the number of teeth non multiple of each other, this way all tooth from one gear mesh with all other tooth of the other gear. This way you spread out the wear since no two tooth are exactly equal
Another point, make the middle gear more robust, it doesnāt appear, but the loading is way higher, almost two fold, maybe make it metal
I donāt know if itās a good idea to make all gear plastic since you donāt have a gear that keep the profile with wear, making the middle gear metalic solves this too
You use Blender for CAD?
Yes. So far, so good!
Yup, module 2 seems to be more than strong enough with 3D printed plastic
Use F360 / Inventor or any free CAD modeling software. Blender is just too complicated to get a thing done. I would never even think about using Blender for such a purpose.
Sounds pretty good, we have gone for 15mm wide spur gears, is there any reason for us to go wider
Thanks for the good advice
I am using 15mm aswell, I dont think any thicker is needed. And your gears out of cnc`d POM should be even stronger than my 3d printed plastic ones
Yes of course POM is very good.
We have reduced the overall size of the gear box now, going for 25-17-10
You have some more pics?
I will do soon, I will PM when I done - share some ideas
3D printer is broken down right now so nothing physical yet.
I keep hearing about Fusion. Iāll see whatās on Youtube, but I have unfinished business with Blender!
Its not the enemy
Fusion is great, basic and simple to use
i love this design, are yāall gonna post the files or is this going to be intended to be sold?
i was wondering if this was going to happen, now my question is, since it has 3 gears can this be made to fit SR trucks? the issue me and Kug talked about was clearance but this solves that problem
It can be made to fit SR, but I dont have SR so at the moment it cant be done
SR = surfrodz right?
Whatās your mounting solution? Can I see the backside?
Maybe a bit later
