New Hummie Hubs!
IMG_20181013_205049 IMG_20181014_172014 IMG_20181014_172018 IMG_20180920_235120 IMG_20181014_180631
Hey guys. Life got a bit complicated, but found time to move this build forward.
It’s 15s A123 (49.5v nominal 54v full). focboxes are stock firmware with M 60/-60 B 30/-12 switching frequency 30k 57v batt max 130a abs limit
I’m still on stock bushings, so I didn’t have the nuts to let it all out. I got to 28mph easy with these settings (200lb). Tons of poke, very good brakes (83mm wheels must help with that).
Some numbers: 53v (down to 50v, sag to 41.1v) 2500w M 84a B 59a 40degC max 30wh/mile
I think I’m already happy with this performance! It feels every bit as good as 2x6354 10s4p, accelerating and braking. I have a lot of untapped performance available. This gonna be fun. :slight_smile:
Things I still need to do:
  • riptide bushings (I have them, just gotta swap them in)
  • @ackmaniac firmware (thank you man!)
  • 100a/-80a motor max
  • 50a/-20a batt
  • maybe bump the max battery voltage a hair
  • maybe bump abs current max a bit
  • double check all the erpm settings
  • replace the missing screw on front truck doh!
  • wire loom phase wires
  • housing for loop key
  • charge port
Oh btw the 1/4" aluminum plate for the focboxes were too much. Replaced with 1/8".
I should wait until it’s had a few dozen miles but, thanks @hummie amazing stuff! Thanks @pshaw @Deckoz for pushing the voltage barrier.
I’m so happy to see you followed through and kept the shipping labels on. That’s great. :joy: And thanks for posting your settings!
Really like the pull cord on n off on top. Not so clean in this instance (maybe I’ll print One just fits the baseplate ) but got to be the easiest. And ur saying a button there would be easier and it would be until it breaks! I have yet to see a reliable switch. (Looking forward to trying the 6.6s).
What are those motor plugs n why not just bullets? Like ur velcroed holder.
Tool should be here tomorrow and and give me this week. Other taps come later in the week. No problem. I have 15 sets here almost done.
I’m really tickled by how it worked out. Proudly on display forever :slight_smile:
Why? Better insulation and mechanical separation, will survive some abrasion, less likely to pull out with 3 ganged connections, can’t mess up the order of the phases once it’s on there.
If you look close there’s a printed wire organizer in there between the bms and focboxes. Been thinking forever on how to get control of the bird’s nest that always seems to happen.
i need those hubs lol
And I want to give them to u.
Ok the plugs yes sounds safer. Common dangerous shorting.
I wonder if ur pushing inductance high for the big capacitor with the long battery wire with the plug.
What do you mean my wire loom phase wires?
Where’s ur other goofy pic with closeup n smile? IM using my hearts :two_hearts: pairing w insults.
I’ve been wondering too. the positive is making a really long run. shiver… I’ll read up again.
https://www.amazon.com/gp/product/B01MU7EKPC
I bought a few types – this stuff seems much better than the typical. Somewhat sealed, and much easier/nicer to deal with. Tesa tape or self fusing silicone tape (they throw some in with the loom) to seal the ends.
No actually I’m keeping the loop key. I’m just gonna make it nicer, with probably a pull cord for emergency shut off.
I’m starting to play with bms’s (the smart ones), and e-switches (rated for 100a or more). Still don’t trust them lol.
@Hummie, when are you going live on KickStarter and will you be shipping to Australia? Also, here are some hearts (no insult) :two_hearts::two_hearts::two_hearts::two_hearts::two_hearts:
Lol, I thought I’d change it up with another goofy close up smile photo. :smile:
I feel I’m waiting for the mail to show. Ok I’m gunna shut up n go wait for tools quietly elsewhwhere. Ramble erase. This week.
:heart_eyes::heart_eyes::heart_eyes: oh my goodness
Has anyone ever tried hydro dipping trucks? I think it would look great with hubs because you can see more of the truck and you wouldn’t have to remove the mounting. Is it possile to take off the hummie hubs from the truck without breaking anything and are they glued on or screwed on? Thanks
You can take the motors off the truck w an m8 Allen wrench n two pin spanner for a bike
Would I have to glue it back on or something of that nature?
Use the same tools to put back on.
Thank you. Ill try it and post a pic eventually. It will be a while though.
In case anyone lucky enough to get these motors hasn’t seen this.
damn its a slow process but we have the tool, bought one, and doing these starting after work tomorrow. im working the next couple days but will get it done at night and this weekend and I can take off work starting next week and for sure I really plan to have these out by Monday or Tuesday at the latest. its been a slow up with realizing the design had a problem, which showed up when @slerm bent one, so can fix that and feel better sending them abroad where it would be harder to get back and modify. image
this way we really are sitting on a 12mm axle with 20mm of length before threading. 2cm from the butt should be more than enough I think and the threading remaining as well. its all good and a ok advice from machinists. gets worrisome cutting hubs with the stators and bearings all ready attached and ready to go cant afford to fuck that up.
