Anyone seen this?
Probably too expensive for esk8 though.
Anyone seen this?
Seen it, tested it, held it
1000?
Overkill for boards. We did some test lasts weekend. 450A in the power stage at 40Khz switching frequency, FOC. This is more for things needing big power.
Frank
Blown away by itβ¦
I think youβve just saved my entire hydrofoil project (and my arse with Danielle in the process).
AWD trike?
You know that eventually someone will use that on a board donβt you?
What is it actually designed for? Triple jet powered surfboard? Just wondering about the three.
While Iβm impressed, who writes the word soup at the bottom of every productβ¦
I can tell you that it will foil very well. The tests we did last weekend made Benjamin a very happy man. The motor we used is best described as a short circuit. Windings resemble a 25cm AWG 12 cable.
absolutely brilliant lol!! well done, sir!
Its one vesc, cables are just to devide and conquer the awesomeness that it provides.
Wow. Definitely overkill for a board then. Some one will do it though.
Probably Benjamin will do it this week. The drive train will be rather unconventional. No gears, no belt, direct thrust drive.
Ha, someone needs to get two of these and do a 6 wheel drive build!
Is it 75V 300A or 75A 300V?
Website says bothβ¦
Probably 75V 300A. 300V is too dangerous.
Why can this vesc runs 3 motors? and not 2?
Each bundle of wires is for ONE phase. This only drives one motor.
This thing catapults VESC directly into e-bike territory guys. I know there are forks with super high power but this one with compact package is a good thing IMO
@trampa wish you fair sales on this, it can only expand Benβs work in a good way. Still hope it wasnβt this expensive, Iβd like to compare it with similarly priced e-bike controllers (performancce wise).
