Hello! I’m building my first e-longboard; I have lots of experience with small-scale electronics (Arduino etc) but never worked with big LiPos or BLDC motors. Planning some really cool and complex aspects to this, but I’m starting with the basics and was wondering if I could get some reassurance before I pull the trigger on this expensive stuff!
Definitely not just preference. Quality. And 30 bucks shouldn’t make or break your build. And You’re trying to go 12s. 4.xx hardware and 12s is not a good idea.
Dang, wish I’d found this place before jumping the gun to get that since it’s no longer returnable I’ll look into the Focbox… $30 certainly isn’t a problem but $200 might set me back a bit Other than that does everything else look good?
That’s where the cool complex stuff comes in, I’m working on a folding design for the deck/enclosure - I’ll do that later down the road (and of course helmet is a must, I do skate). For now I’m just trying to get these motors spinning as well as I can, without blowing anything up lol (might slap it on an old board and take it around the block as a test, but not much more - this is mainly R&D right now)
I imagine a little cardboard and duct tape would do the trick for testing, or maybe a small storage bin. I’ll design and 3D print something if I wanna actually use it regularly
I had lipos in my build for several years, it can deliver high A, but it had to be constantly maintained well, and im a bit scared after all these years. next battery ill make with 21700 batteries. please check if you need lipos, they are a bit specific. i always had to change it separately and now wish to have simple plug-in charger like for notebook. and after 2 years they became a bit “puffed”(just a bit) and i had to tighten them with aluminium plates. but its not recommended, “puffed” ones considered to be and the end of lifetime. it cannot stay fully charged or discharged more than a week as it will degrade faster and cam became “puffed”. if you want more details, PM me - i use it for more than 4 years in esk8 and have thoughts to share
I had similar remote but it called “nano”, it had other reciever. and i did not liked it. this had perfect form-factor, but i experienced signal drops and overall weak signal. maybe as its a bit different remote it might be good, i think you may want to ask someone who has it if its good. i had to switch to mini remote (a bit ugly) and signal was perfect and reliable
That’s fair, I am doing things a bit out of order. Lemmie essplain:
First of all I’ve been skating casually most of my life so I do have a helmet and am generally careful. I always ease slowly into things, but I do tend to push limits when I get comfortable.
Ultimately I’m planning to design and build the deck and enclosure from scratch, so I’m going off the mindset I usually take with other projects: pick electronics first, then build the mechanics around them. If it don’t fit, just make it fit!
Flex is something I hadn’t considered, I’ll be sure to keep that in mind throughout the process. If needed, I have a “semiflex” TPU filament I can print with instead of rigid PLA or ABS.
Unfortunately I had already jumped the gun on both the motors and the ESC, and I feel like it’d be easier (and astronomically cheaper) to keep the motors and find a battery/ESC that works with them. I’ll keep the right order in mind if I make other esk8’s in the future!
Everything else I’m pretty much following; my wheels match my motors, remote for now I just need something that works (Once the other stuff is done I’ll be designing that from scratch too), and of course aesthetics are last
That being said, I will do some more research on traditional enclosures before doing anything else - seemed simple enough but I could totally be overlooking something
Remote came in the mail today and I set it up with Arduino just to get a feel for it. Made a little visualization program with a throttle bar, it seems pretty good and connection seems solid. The thumb wheel itself is pretty cheap and doesn’t feel great but I think it’s useable. Focbox and battery stuffs are in transit!
