I wanted something that slots into the wheel and is naturally held in place by the belt positioning and the motor mount. I’m fairly sure it’s a product but I can’t find it anywhere online.
Also, to top things off - I want a 15mm belt to fit on it and maybe made out of metal because I’m an 80kg rider and don’t want the teeth to break while going down hill! I’m not the most confident at speed so I’ll be braking regularly.
I’m also from the UK. Looking to get the motor mount, a motor and the pulley system this month and then all the other bits next month.
fair enough, personally when putting KW of power through a drive train id rather high tensile bolts over ali or plastic pins. i was running the alienware pulley now im running the eskating.eu one both bolt through but are good solid pulleys
@moon If I went for one with bolts would I still need to modify my trucks? I don’t mind modifying, but would prefer not to because I may end up changing them in the future.
@electricjim79 That’s a very good point. I guess I could get some black bolts which will blend in nicely. Do you know the answer to the question above?
There is currently a preorder going on for pulleys from @JLabs. They have a integrated bearing and from what he has said it doesnt need to modify the trucks.
