Yep, it doesnt
Ok thanks a lot.
Do I need a resistor as well for an xt90 or will it work fine without it.
Also can I just plug the wires directly into the soldering tabs on the xt90s or do I need to use bullet connectors
Just solder it
Also do I need a capacitor
Or resistor, not sure which one is correctđ
If you buy an anti-spark XT-90s you dont need a resistor, just solder the wire and ends on. You put the XT-90s in the middle of the positive circuit. Look at the Beautiful Diagrams thread, there are a few XT-90s diagramsâŚ
Ok thanks a lot
It looks like thisâŚ
THat is a cutout from the entire schematic which look like this, so you have a better idea of what it should like like as part f the entire electronics structure.
Ok cool thanks
im not the best a soldering
Heat shrink the ends, and make sure your using an iron that really hit so you get a good flow. Also a helping hand will make like a lot easier, just Google helping hands soldering stand.
i didnt put heat shrink on before i soldered them though
can i just use regular electrical black tape
dude cmon⌠if you donât even know the purpose of electrical tape you shouldnât be building a board. please dude, itâs not because i hate you or anything, you just gotta get the basics down before attempting to build something as complicated as a board.
practice your soldering skills, read, read and read
i have no access to heat shrink, why i cant use electrical tape?
i didnât say you couldnât use electrical tape. electrical tape is fine. my point was that if you canât figure that out yourself you shouldnât be building a board. again, not trying to be mean, just telling you the reality of your situation
ok thank you
