I currently have 2 esk8s one is a longboard and the other is a short board (20”). They are both currently out of commission and waiting for parts to arrive so I can do some transplants and upgrades.
Build 1
This is going to be my high speed adrenaline board. I want it to have lots of torque as well as lots of speed (I know that’s what most want) here’s the plan
12s1p lipo
2x 190kv 6356
97mm clones
10:27 chain drive
2x Tb vescs
Extra 19800uf cap bank
Hk trucks
2x Custom motor mounts
Custom styrene enclosure
With those parts I’m looking at just over 50km/h top speed and 15-20km range.
So far I have the motors, batteries, vescs (thanks @Funktapus), capacitor bank, trucks and wheels, 1 motor mount and the chain drive. I’m only waiting on some plastic to make an enclosure from and some bits and bobs. Now onto some pics
This is the capacitor bank, it’s only about 25mm think you it can be laid on it’s side
No roast needed. It’s just for smoothing out extra voltage spikes. I’m kinda paranoid about running 12s on tb vescs so I want to try and do everything to stop them from frying
I’m running a 12s3p on the VESC’s, 6 months not and no worries. One of the things I’ve found that helps is using a liberal throttle cirve so as to not throw too many amps in an instant at them.
Keep in mind this is Lipo at 12s1p, so realistic, conservative output, depending an capacity and C rating should easily be at least 50-60+ amps. That threw me for a loop as well. I saw “speed board” and 12s1p and was like whaaat? Oh, Lipos. NVM.
Haha yeah, I love lipos, super easy to use and can be just as easy to charge as liion by adding a bms. And they are pretty much just as safe.
From personal experience shorting a lipo does not cause it to catch fire, I shorted my first lipo multiple times and all that happened was the nickel strips split and burnt out. I see this as a great safety feature since it stops the short immediately
I have received most of the parts for the second build so I thought I’d start putting that together while I wait for the parts for the other build. This is more of a left over parts build with a few small upgrades.
Parts list:
Keda 6364 190kV
5x 2s zippy 5000mah 20c
Dual eBay esc (I broke 1 phase lead inside the esc so I’ll be running it in single drive)
10s bms (charge only)
Old longboard deck painted matte black
Enertion power wheels 83mm
China pulley kit (will get welded to the trucks)
Paris clone trucks
I think that is most of the parts so it’s time to get building
Please mind the mess, having two board being built at the same time creates so much stuff. I’ll get some more pictures up as I build and should have some pics of the other board tomorrow
