Designed to turn rookies (like myself) into a reasonable cookies
Decorated in a safety orange and white colour scheme and built upon a 40.5" downhill longboard deck, Rookie Cutter is my first attempt at a fast and flexible cruiser.
Looks good, I live in Aus too and I can highly recommend either 97mm wheels or genuine flywheels. I don’t know if it’s everywhere but the road where I live are pretty chunky and my 83mm wheels make my feet a bit sore after a while. If you don’t already have them get 97mm at least
I found a lot of larger and genuine wheels to be fairly pricey at above the $130 locally, hence why I picked up a cheap pair with my trucks from Amazon US. How much did you pick yours up for?
A clearer diagram of my balance only BMS charging setup. Took @Jinra 's advice on the matter and brought the LCD monitor electrically closer. Could someone help verify my diagram?
I think that ID was around 2mm smaller than needed
Maybe you’ll be better off with printing a pulley, buying from HK ( if you find them available ), paying more and buying from forum members
You will have a hard time with that motor mount and the caliber trucks. The motor you bought also won’t be very plug and play with that mount. I think you should chuck the turnigy mount and get one made for caliber trucks, it will save you a lot of headaches.
Last few cables and connectors have rolled in as well as my first mounting attempt:
Clearance was too close to the board so I’ve got some 14mm risers coming!
The pulleys fit perfectly after a little file, and came in a blazing red which is a happy surprise
