ok, i guess perspective comes in to play. given the choice, which would you run?
Kind of depends on the build and environment. AT setup, 63s are where it is at.
Urban boards where weight or clearance is a concern, 50 will be enough and you’ll get more range. Gearing and the correct KV can make a big difference.
SK3 is a good near middle point too at 59mm. Wish I had jumped on the sensored group buy…
Not haveing good luck with torqueboards motor. Broke fast while off roading and customer service sucks.
I noticed your motors use the same 3 m3 screws on the front design as the SK3 motors. everysingle one of my sk3 motors have failed at that point when taking my MTB off big jumps. Have you done any long term testing with your motors off big jumps? Or do you simply just advice agents going off any real MTB jumps all together?
Hi Homer900, our motors feature 12 M4 holes. If you want to go for crazy jumps, just make use of more bolts to fix it to the mount.
Frank
