a little scratch from the outside while I was trying to remove it from the case
PRODUCT FEATURE
ESC:
The W2 ESC uses a customized Hobbywing ESC with sensors. As other Ownboard models it still has a smooth acceleration & braking but with a faster startup speed and a more powerful hill climb ability. High discharge current of 40A.
Reason selling : Only using the enclosure on dual VESC instead!
Looking for $60 include shipping
Or pickup Brisbane
That hearsay or have you tried it? On the diye site its very specific that you can’t mix and match but there is nothing on ownboards site as far as I can find. I hooked a diye belt esc to hubs and they worked but were a bit rougher is all.
I also have a supposedly belt version Diyeboard 1.1 running my Meepo 1.0 hubs and it works pretty well. So entirely possible the same is true in this case.
Hi. 90% chance it will work. The reason why they say is for belt or for hubs, is because is fine tuned for those different drive. So it will work, meaning wheels will spin, but probably the ride won’t be as smooth as is suppose to be with the Hub ESC. Anyhow to me, with the current price of 4.12 VESC why even bother to test ESC?
No thermal issues for me @25A battery and 80A motor each hub.
@rey8801 has a strong point when Flipsky implements the upgrades to solve the 4.20 issues why bother with the Ownboard ESC?
Had my focbox powered ones way over that…
@rey8801 thanks man I knew you would know. Its a replacement esc for my sons meepo and Its round the corner. Hes 11 and I like to keep things slow for him.
Ah I see, well in that case I would still rather go with the vesc so that you can set it actually low and not that if he change the mode can compete with dad’s car
Talking to me even though you haven’t received my finger yet. lol. I’ve ran a belt drive esc with hubs before and it was just a bit rougher as I said but with the ownboard being a better unit (mine was v1) I was hoping it would be ok.
