Hey guys, I’m having trouble with my setup. I have a Focbox Unity with Wowgo AT hub motors. Everything works great when I’m moving but starting off the motors stutter so I have to kinda kick start.
Is this something I can fix in the Unity app on my Android? I ran the setup for the motors and I’m running them sensored. I’m running everything at 60 amps output since that’s what my battery pack is.
If you have sensors and it’s still stuttering, then it’s likely a configuration issue. Are you sure it’s running in sensored mode, and did you do the proper motor setup?
I don’t know the KV as Wowgo doesn’t publish that info. No gearing as the Wowgo AT motors are hub motors. And yes, as I said in OP I ran the setup and I’m running in sensored mode.
Actually you didn’t. There’s is a very distinct difference between sensored and FOC. You might be a little more receptive to advice and do some research so you know what questions you ask.
Interestingly enough, I re-run setup and a small status bar at the bottom says “Both Motors Sensorless” for a split second. Perhaps the wires aren’t in the right place? I thought it was able to auto detect the various sensor wires too?
When you say “full tool” do you mean the Windows app? Ugh, making my life so complicated with my Mac and iPhone! Haha. I’ll run a Windows VM and pray I can talk to the device. The firmware is the latest it said to upgrade to via the app, not sure the version #.
