Jinra
May 2, 2019, 7:00am
2
Lol mislabled the sensor port order just like the early edition focboxes. Where can we get this?
Am I right to think that this is a bit low for a continuous rate? The FOCbox and the vesc 6 can do 50 and 60 respectively…?
Jinra
May 2, 2019, 7:11am
4
The appeal isn’t power, it’s the size. Seems good for boards with limited space.
b264
May 2, 2019, 7:11am
5
This is 50mm x 50mm x 10mm though. If you want “small”, this sounds like the go-to ESC
If the heat dissipation is sufficient, a continuous current of 50a is also possible.
Very clean looking!
My main question is how it’ll compare to something like the new mini fsesc 4.20? That’s almost as small, and it can now also handle 12s and has a continuous 50a rate.
b264
May 2, 2019, 9:14am
11
“Super mini” is no joke.
I like this. I like this a lot.
But I also run very conservative settings, like battery max at 30A, et cetera
The only issue I see is those switches, once they have conformal coating brushed all over them (for waterproofing), they probably won’t work anymore.
In all honesty Brian, this is a problem for maybe 5% of the esk8 community. I get why you do it of course, but most of us don’t.
Surfer
May 2, 2019, 12:40pm
13
Is a problem for 1% of the public in this forum.
Surfer
May 2, 2019, 12:43pm
14
@YUTW123 , congratulation with your design, it looks really well done.
Mad props man!!
I like to conformal coat too, what functions do the buttons have?
And the 4 leds?
agree, this would be great for single motor grocery getters
Where did the big ass caps go? Nice footprint.
https://www.ebmakers.com Thank you for your support.~~:狞笑:
Ixf
May 4, 2019, 2:03pm
19
https://www.ebmakers.com/collections/x-esc/products/xesc-6-6-dual-drive
不好意思請問一下,你們dual的圖片是對的嗎看起來好像只是Single.
還有想請問一下你們遙控器有更多的資訊嗎?
LCD可以顯示什麼資料?
moon
May 4, 2019, 2:08pm
20
Have you got performance videos?
